Author Topic: Glue only for MDF cab?  (Read 2437 times)
  • Last login:Today at 12:12:38 pm
« on: November 18, 2006, 10:38:01 pm »
I glued up the panels for my cabinet this afternoon and it seems pretty sturdy.  DO you think I need to add screws or brackets or anything (I do have interior support pieces that reenforce the joints).  Any thoughts?  Pics: www.bellasarcade.blogspot.com
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
Re: Glue only for MDF cab?
« Reply #1 on: November 19, 2006, 09:11:38 am »
What kind of glue?  Woodworking glue or liquid nails?
People actually playing on the cab won't be as hard on it as moving it.  With MDF your cab will likely weigh close to 400 lbs.  When you put all that weight on a dolly it might be a problem.  I'm speaking strictly from what I think and not from something I know ;)
dot
« Reply #2 on: November 19, 2006, 09:52:48 am »
I used woodworking glue.  I'm building an 80% cab with an LCD monitor - it's heavy but not as heavy as some full sized cabs with CRTs in there...  I think I'm going to get some L brackets and install them on the interior of the cab - no one will see them and it will be peace of mind for me...
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #3 on: November 19, 2006, 01:55:05 pm »
The wood blocks and glue is a tried and true method of building and should hold up well. I've been building cabinetsof all kind for about 20 years and never had problem with breakage although some warping can occur if not braced enough.
My only suggestion would be to use polyurethane (Gorilla )glue on any joint that will house something heavy like a CRT.
Good luck on your project and keep posting updates.
There are three kinds of people in the world those that can count and those that can't.
Pixelhugger
  • Last login:October 14, 2025, 10:53:10 am
« Reply #4 on: November 20, 2006, 12:27:39 am »
Not sure how this translates to a composite material like MDF, but in the case of a wood to wood joint, the glue bonds as strong as the wood itself. Any screws or nails really only serve to align the joint and provide compression while the glue sets. Since MDF is fiberboard I'm sure its a bit different, but I'd think those reinforcing blocks you show on your website will add plenty of rigidity... much more than a handfull of screws I'd think.
Project mega thread HERE
Bill Mote
« Reply #5 on: November 20, 2006, 08:09:43 am »
MDF is a glued product.  I just wasn't sure how well the glue would penetrate the surface and create a good bond.  Again, I'm not a carpenter or structural engineer.  Just speaking from what I "think."  I would think that Gorilla Glue or Liquid Nails would be best.  I glued and screwed every joint on my cab.  I used wood working glue.  I wasn't worried about using anything stronger due to the screws.  Also, I screwed from the inside on my blocks into the cabinet walls so I wouldn't have screw holes visible on the outside.
I've moved the cabinet 2x.  Once from the garage into my living room and another time to a new house and into it's basement.  I have *no* joint issues.  We're going to move in about a month.  I'm taking the TV out before we move this time ;)
dot
MYX
    • MYX Digital Blog
« Reply #6 on: November 20, 2006, 08:21:01 am »
My cab was fully built with glue (elmers wood). Asside from the day that the whole cab fell off the sawhorses and fell 3 feet to the garage floor and somewhat disassembling it, (this was due to some really bad judgment on my part) the cab has been suprizingly rock solid. Ghaw, if that wern't the run on sentance from hell.
M    Y    X
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #7 on: November 20, 2006, 08:46:48 am »
Don't know about the glue thing, bug your marquee designs are very cool!  :cheers:
Robots will kill you.
Arcade Addiction
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #8 on: November 20, 2006, 08:47:29 am »
MDF takes up the glue, very well indeed.. Beter than wood does. It's very porus in its raw state and quite literally sucks up moisture. So the bond should be very strong once set.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #9 on: November 21, 2006, 09:25:07 am »
When i built my bartop, I used glue on all joints, and for piece of mind, I also put a couple of brad nails in also. They have very small heads, so easy to hide.
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
