Author Topic: MaLa - Can i alter the "Exit menu"  (Read 3172 times)
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« on: November 18, 2006, 08:55:02 pm »
I would like to know if I can edit the order of the "exit" menu in MaLa.
My issue was highlighted to me because I have an older P1 start button. Sometimes it sticks and sometimes it takes a more solid press to work
To get to the exit menu in mala i press P2 start, navigate to "exit" and hit
P1 start.
Everynow and then (due to me and the button) I double hit the P1 start button. This causes mala to exit to windows.
To shut down my cab from here I have to open the cab, install a mouse and use it to shut down.
It would make it a whole lot easier for me if "shutdown" was at the top of the exit menu and exit was the next one down
Is this possible?
ta
If it ain't broke give it to me...i'll soon fix that
loadman
  • Moderator
    • MaLa
Re: MaLa - Can i alter the "Exit menu"
« Reply #1 on: November 18, 2006, 10:12:38 pm »
You could have it set up like mine... See attached pic
I don't use the menu at all.
If I want to shut down the PC I hit P1+P2 then P1 to confirm (or P1+P2 again to cancel)
If I want to exit to windows (where I will need a mouse really) I right click and quit that way..
