Author Topic: Marquee too bright!!!  (Read 3000 times)
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« on: March 26, 2003, 06:44:16 pm »
Hey guys, I finally got my printed marquee and when I put it on the machine it seems too bright.  How are you guys counteracting this?  Are you just painting a clear piece of plastic white to diffuse the light?  I thought I saw some people doing that in the past, but I'm afraid that will just make the plastic opaqe and not let any light thru.
Please help
wee beastie
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:Marquee too bright!!!
« Reply #1 on: March 26, 2003, 07:21:40 pm »
You could try putting a piece of paper behind your artwork to difuse the light.
Coming Soon
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #2 on: March 26, 2003, 07:51:10 pm »
they make white plexi, you could sandwich your marquee between a sheet of white and a sheet of clear plexi... or if it's not enough,  find a busted piece of flouresent light fixture covering and put it in front of the tube - difuses quite well..
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
SNAAAKE
  • -Banned-
« Reply #3 on: March 26, 2003, 09:21:40 pm »
I actually had same problem LONG(very long) time ago and I bought like a cover that goes with the tube light.
Worked great and wasnt too bright.
Hobby store or light stores should have them(I got mine from chinatown).
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #4 on: March 27, 2003, 09:06:54 am »
My marquee is printed on backlight-film -never would I go with anything else! :) It's clear and has a white back where you print the mirrored image. Light gets pretty diffused, the sides are a bit darker but I guess this is only authentic, and 'cause of my loudspeakers my fluorescentlight is only a few inches behind the glass.
I guess a thin white paper should help in your case.
Chris
    • Chris's MAME Cabinet
« Reply #5 on: March 27, 2003, 10:36:08 am »
Even if you spray-paint the rear plexi white, plenty of light will shine through it!
--Chris
Carsten Carlos
« Reply #6 on: March 27, 2003, 10:52:16 am »
How many watt's has your lamp or fluorescent light? I've 18 Watt installed - though less would have been enough, too.
seaner
  • Last login:October 21, 2003, 02:10:16 pm
    • http://www.beerbot.ca/mame
« Reply #7 on: March 27, 2003, 12:06:32 pm »
A sheet of white mylar would also do the trick by diffusing the light more.  Double it up to cut down the light more?
Get a lower wattage tube?
MrTeamWork
  • Last login:June 24, 2003, 04:08:42 pm
  • On a quest to build my cabinet!!
« Reply #8 on: March 27, 2003, 03:13:52 pm »
I don't know if it's this simple - but why not get a less radiant bulb?
s8n
  • Last login:April 02, 2003, 06:12:12 pm
  • The Prince of Darkness
« Reply #9 on: March 27, 2003, 05:32:30 pm »
mine is sandwiched between 2 pieces of lexan, for the back piece i just left the white film on the lexan, but obviously peeled it off the front piece. my marquee is also printed like a decal, and that also has a paper backing.
CustomArcade
  • Last login:September 22, 2003, 10:38:34 pm
  • Who's Your User?
    • VoodooMachine
« Reply #10 on: March 28, 2003, 03:27:46 pm »
Ignore this test
"Anything is possible, but the odds are astronomically against it."
romid
  • Last login:November 17, 2008, 02:33:12 pm
  • MAME rox your socks!
    • Temp MAME pics
« Reply #11 on: March 28, 2003, 04:50:36 pm »
test ignored...
Actually I have the same problem.  Im not sure you can just get a lower wattage tube-- flourescents are designed for a specific wattage, no?
