Author Topic: Determining Exact Size for a a Monitor  (Read 2032 times)
twitami
  • Last login:December 22, 2016, 01:09:08 pm
« on: November 10, 2006, 07:14:03 pm »
Ok, this sounds a little silly, but since I can't find any model numbers on the monitor I took out of my Mame Project's Cab, I need to know EXACTLY where to measure from. I thought it was a 25", but when I measure the unit outside of the cabinet, from complete farhtest part of the edge diagnally, I get like 26-7/8 or so. So is it really a 27"?
If anyone out there can give me the a very accurate measurement of a Betson, or a billabs 27" that would be great. The EXACT measurment horizontally would be the easiest to use, as the cabinet has 23-3/4" space.
Thanks so much!
Brian
SirPeale
  • Green Mountain Man
Re: Determining Exact Size for a a Monitor
« Reply #1 on: November 10, 2006, 07:52:52 pm »
Post the number on the back of the tube.  Likely starts with an 'A' like 'A68xxxxxxx'
The number right after the 'A' is the tube size (diagonal) in CM.  So 63 is 25", 68 is 27", etc.
twitami
« Reply #2 on: November 11, 2006, 12:21:34 am »
Well, it is a Zenith tube, and it has the a sticker with all sorts of info, and one of the numbers is A63G....
So I guess that means it is a 25". Which means I am screwed :(
SirPeale
« Reply #3 on: November 11, 2006, 01:21:14 am »
Why are you screwed?
What's wrong with your old monitor?
twitami
« Reply #4 on: November 11, 2006, 02:44:13 am »
Old one doesnt work. Wanted to get a Betson or billabs for the MAME conversion, but I don't think they will fit. The monitor that was in there (the 25"), was a tight fit as it was.
SirPeale
« Reply #5 on: November 11, 2006, 09:28:59 am »
Figured the old one doesn't work.  But it's possible it can be fixed.  If you're interested, that's what we have this forum for!
twitami
« Reply #6 on: November 11, 2006, 10:13:23 am »
Nah, it's only standard res, and I really want a unit I can run MAME on, and run windows games on. Gonna go look at TVs today. Anyone ever decase a 27" HDTV? One at Best Buy for like $379.00.
SirPeale
« Reply #7 on: November 11, 2006, 03:09:50 pm »
Is it a K7000?  If so, you want to get rid of it?
twitami
« Reply #8 on: November 11, 2006, 05:15:46 pm »
Not sure. All I know is it is a Zenith tube. There isn't much else on it. There are a few stickers with WG and some numbers, but Wells Gardner's website doesn't list it, nor give any results when I use the serial number search.
SirPeale
« Reply #9 on: November 11, 2006, 05:44:36 pm »
Can you take a picture of the chassis?
twitami
« Reply #10 on: November 11, 2006, 07:57:19 pm »
Sure. Then I just need to figure out how to post them here :)
SirPeale
« Reply #11 on: November 12, 2006, 01:45:12 am »
When you go to post hit the link just below the text box that says 'Additional Options'.
