Author Topic: Sound issues caused by computer speed?  (Read 1436 times)
More Cowbell
  • That's just dumb!
« on: November 08, 2006, 11:05:49 am »
I just want to confirm my thoughts on this and your input is appreciated. I am putting together a MAME cabinet with a free computer someone gave me. It's a PII or III and it can't be more than 500Mhz. Some of the more common games are having an issue with sound. The sound repeats itself during gameplay even thought the game plays fine. Old games run fine with sound, but some games like 1941 have the repeating sound syndrome. Is this due to the computer speed? Is there a way to adjust the sound settings in MAME to get past it at all?
I've got a fever...
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: Sound issues caused by computer speed?
« Reply #1 on: November 08, 2006, 11:57:10 am »
you need to run a older version of mame, the  computer is way to slow for new versions you might try .86
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: November 08, 2006, 12:29:37 pm »
lower the sound quality setting from 44100 to 22050
NO MORE!!
ahofle
    • Arcade Ambience Project
« Reply #3 on: November 08, 2006, 02:43:08 pm »
It's almost certainly due to your computer speed.  Press F11 in game to confirm whether or not you are getting the full frames per second.  If not, sound is usually the first noticable anamoly.
More Cowbell
  • That's just dumb!
« Reply #4 on: November 08, 2006, 04:48:59 pm »
I keep forgetting that the MAME version plays into the speed somewhat. I got my first MAME cabinet to run all of the NBA Jam games by rolling back to .67 or so. I'll try that and the sound quality trick and see where it goes. F11 sounds like a good comparison check.
I've got a fever...
SirPeale
  • Green Mountain Man
« Reply #5 on: November 08, 2006, 07:51:12 pm »
For the archives: whenever you're having stuttering sound, always check your FPS with F11.  Most of the time it's because your CPU isn't fast enough.
Sometimes you can tweak things a bit by lowering your resolution.  If you're running @ 800x600, lower to 640x480 (or even lower if you can!).
AlanS17
    • AlanS17
« Reply #6 on: November 09, 2006, 01:01:31 am »
I would start by cutting the audio sample rate in half and then setting a fixed frame skip of 1. See where it all goes from there.
