Author Topic: Mala Not Starting With Windows??  (Read 6159 times)
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« on: November 05, 2006, 04:58:04 pm »
I recently tried to get Mala V.1.0 RC8 (Mame Command Line V.1.09) to automatically launch when my computer boots up.  I have turned the feature on within Mala and have even tried to load it through the Start up group within WinXP.
Is there some little switch somewhere that I missed??
John
Galaga... Was there any other game?
loadman
  • Moderator
    • MaLa
Re: Mala Not Starting With Windows??
« Reply #1 on: November 05, 2006, 05:32:10 pm »
John
When you enable it I think you need to be 'administrator' as it changes something in th windows registry.
I could be wrong as I don't use that anymore. I have MaLa set up as the shell.
BamBam
« Reply #2 on: November 06, 2006, 07:39:12 pm »
[/quote] I have MaLa set up as the shell.[/quote]
What do you mean by setting it as the shell? Sounds cool.
I have a dedicated cabinet that I use as my arcade and Jukebox.  The Jukebox side isn't fully ironed out yet.  Any suggestions on what Jukebox to use?  I recently upgraded Windows Media Center 11 and actually like it.
John
loadman
  • Moderator
    • MaLa
« Reply #3 on: November 06, 2006, 08:28:55 pm »
It basically means having MaLa(or any fe)  launch in place of windows explorer to hide windows.
Have a look here:
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
You probably don't want to do this if you are using your cab for other things too
Personally I like UncleT's and  SK Jukebox
I am yet to try. Do you need a Legit vers of Windoze to run it? . I only have one of those
BamBam
« Reply #4 on: October 17, 2009, 10:18:02 pm »
UnQuote
Loadman,
I believe you need WinXP or greater to run it.  Sorry for the extremely late response.
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« Reply #5 on: October 18, 2009, 06:27:09 pm »
To load MALA instead of the Windows desktop/environment:
Run regedit: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon Userinit
c:\WINDOWS\system32\userinit.exe -----> d:\mala\mala.exe (change the path to your file). In the case that you wish to run one program or several programs even before MaLa starts (for instance, scripts), you have to edit the line like this: d:\mala\idle.exe, d:\mala\coindrop.exe,d:\mala\mala.exe that is, the path to the .exes in the order you wish (separated by a comma). This modification, if wrong, may cause your system not to start, so make a Ghost image backup of C:\ before.
BamBam
« Reply #6 on: October 25, 2009, 05:50:53 pm »
Thanks Stormrider.
