Author Topic: Strange problem with Mala?  (Read 3254 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: November 05, 2006, 04:01:43 pm »
I have been having this strange problem when using mala.  If I leave my computer up and running for a length of time(I'm guessing around an hour, not exactly sure how long it takes) the screen goes black and the computer freezes up.  This only happens when mala is running or when a game launched from mala is running.  It happens regardless if someone is using it at the time or not.
It has happened with 3 separate computers.
As far as the power options, everything is set to never turn off.
This doesn't happen when using other frontends.
I'm curious if anyone else has had similar issues and if anyone knows a possible solution.
loadman
  • Moderator
    • MaLa
Re: Strange problem with Mala?
« Reply #1 on: November 05, 2006, 05:29:37 pm »
Never heard of that one.
You may want to enable the debug log (on the help and credits tab) and send in the file (MaLa.exe.log) to SWINDUS
Note after you enable it I don't think it creates a log until the next time you launch MaLa
