Author Topic: Securing joystick ball top...  (Read 6003 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« on: October 30, 2006, 04:55:47 pm »
I have the Ultimarc J-Stick w/Ball top.
It seems to come loose after some play.
Would like to secure it so it doesn't come loose but still have take it off later.
I know there was discussion on securing it in a previous post but cant seem to find it.
Teamwork - A group of people running around doing what I say.
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
Re: Securing joystick ball top...
« Reply #1 on: October 30, 2006, 05:19:54 pm »
Have you thought about a removable threadlocker compound?
MameJunkie
  • Eeeeeeeevil
« Reply #2 on: October 30, 2006, 05:57:54 pm »
Possible...is there anything cheaper?  IE free?
...toothpaste...honey...tootsie roll...snot...
NickG
  • Dig.
    • My Projects Page
« Reply #3 on: October 30, 2006, 06:03:06 pm »
dunno... maybe some elmers white paper glue might help it stick, and still be removable  with force.
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
« Reply #4 on: October 30, 2006, 07:38:39 pm »
A good fix I learned while flying R/C aircraft is to use clear nail polish on threads. It is removable if need be. Can't get much cheaper than that.
 Cornchip.
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
« Reply #5 on: October 31, 2006, 12:35:35 am »
you can pick up small tubes of loctite in a local autoparts store for 3 or 4 bucks.
If you do go that route get the blue not the red. The red generally requires a torch to remove which is not a good thing for the joystick. :o
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #6 on: October 31, 2006, 11:30:37 am »
MameJunkie,
Have you tried wrapping the threads with teflon tape?  It is that white "tape" that plumbers wrap around pipe threads to ensure a water-tight seal.
MameJunkie
  • Eeeeeeeevil
« Reply #7 on: October 31, 2006, 11:34:47 am »
MameJunkie,
No...good idea...I have plenty of those lying around.
I'll also try Cornchip's idea of nail polish.
Thanks for all the info...I can play rough again : )
feeras
  • Last login:October 27, 2012, 06:56:50 pm
« Reply #8 on: October 31, 2006, 06:40:37 pm »
With most japanese joysticks (unsure about the ultimarc though I've heard it's made by sanwa) you simply get a flathead screwdriver to hold the bottom bit of the joystick, and turn the balltop as hard as you can. You can reverse turn to lossen the balltop. All sanwa and seimitsu joysticks I've seen are tightened this way. I've yet to see any balltop come loose after doing this.
Hope this helps...
MameJunkie
  • Eeeeeeeevil
« Reply #9 on: October 31, 2006, 06:44:19 pm »
Hope this helps...
I've tried that but either I didn't do it correctly or my joysticks cant be tighten like that.
