Author Topic: Rotating SNAPs in Gamelauncher??  (Read 2062 times)
« on: October 30, 2006, 11:37:55 am »
Does anyone know how to do this?  Everything is set up properly (I think) and I was able to rotate the game list for a vertical monitor but the snaps do not rotate with it.  Is there a way to do this?
THANKS!!
loadman
    • MaLa
Re: Rotating SNAPs in Gamelauncher??
« Reply #1 on: October 30, 2006, 05:29:53 pm »
THANKS!!
Let me think.
I don't think Gamelauncher does that.
I think you have to do it manually first (in a graphics prog) or take new snaps while it is rotated.
I think thats what i did when I used it
« Reply #2 on: October 30, 2006, 08:41:54 pm »
Crap.  That's what I thought.  I might have to give up on Gamelauncher and just work to get MaLa working as close to Gamelauncher as possible.  I need to add the sound effects and figure out how to rotate the games properly [everything is vertical - rotated to the left - and I need to get the horizontal games to be rotated 180 degrees (upsidedown)].  I do love the gamelist features of MaLa though.  Ack!  I hate computers.
loadman
    • MaLa
« Reply #3 on: October 30, 2006, 08:55:13 pm »
I have the MaLa gamelauncher skin on on my cocktail table
If you hate PC's I'm happy to post you a DVD with a MaLa folder on it all set-up basically the way you want.
PM me the details (Rom-set version you have) and what sounds you want and a postal address. It will only take me 20mins as I have done it for others.
Up to you.....
« Reply #4 on: October 30, 2006, 10:35:45 pm »
Wow that would be awesome!!  I'll be sending a PM very soon.
gonzo90017
« Reply #5 on: November 01, 2006, 11:43:14 am »
Or you can download PhotoFiltre http://photofiltre.free.fr/frames_en.htm
Install it. Then go to Tools>Automate / Batch
Where it says source folder browse to your artwork folder then specify an output folder then under Output format choose your desire output format.
Now go to the Transform tab and choose to rotate or flip vertical! Then click on the action tab and press ok thats it!
« Last Edit: November 01, 2006, 11:45:20 am by gonzo90017 »
loadman
    • MaLa
« Reply #6 on: November 02, 2006, 03:17:55 am »
DVD Posted
You could do that, as I said origianlly you can run the snaps through a graphics prog.
Whatever rocks your cab  ;D
« Last Edit: November 02, 2006, 03:20:44 am by loadman »
