Author Topic: XP SP2 w/shell replacement  (Read 1789 times)
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« on: October 30, 2006, 08:32:24 am »
I applied SP2.  Don't ask me why.  I just did.  The cabinet works all the same as posted in my original build script.  There are a few extra services I'll have to disable and whether I'll leave the firewall on or not is up for debate.  Anyway, MAMEWah is my shell.  When I drop out of the shell I'm left at a black screen with the mouse just as before.  I press CTRL-ALT-DEL to bring up the window with shutdown, lock, task manager options and I select task manager.  It opens just as before.  The interesting thing is when I choose File->Start New Task it AUTOMATICALLY opens a command prompt rather than letting me type something in a dialog box.
The kicker is that you can't type in the command prompt either.  This has to be a security "feature," but I can't figure out how/where to change it.
dot
jfh2112
  • Last login:November 27, 2010, 01:27:12 pm
Re: XP SP2 w/shell replacement
« Reply #1 on: October 30, 2006, 03:06:59 pm »
My cab, before I blew the OS away yesterday, was also running XP SP2, and I didn't have that problem. Just tried it on my work PC as well; same thing.
Are you logging on as a local administrator or a restricted user? That may have something to do with it.  :dunno
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: October 30, 2006, 05:21:44 pm »
If you hold down the ALT key when selecting "New Task" from Task Manager it will open the Command Prompt. Seems you may have the ALT key stuck or something?
Bill Mote
« Reply #3 on: October 30, 2006, 06:51:55 pm »
I guess anything is possible, but I did remap my entire MAME key config such that I'm not using any of the "special" keys (CTRL, ALT, etc.)
dot
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #4 on: October 31, 2006, 12:02:17 pm »
I use sp2 and don't have this issue (no command prompt - just a run dialog box).
Is this a normal sp2 installation, or is it customised?
