Author Topic: SOLUTION? - Does anyone know how to automatically restart a program if closed??  (Read 2486 times)
marknetwork
  • Last login:December 08, 2011, 02:17:19 pm
  • arcade building can be frustrating...
    • MarkNetwork.com
Hello,
I am building a Golden Tee cabinet and will be basing it off of the Windows Version of Golden Tee, but unfortunately it gives the option of exiting the program.  I've been looking for a solution to automatically reload the program if someone exits.  Is there a script or a program available to do this?
Someone hits exit, or program crashes >> Program automatically restarts if closed
Anyone?? Anything?? Please oh please I have been looking forever!!
Thanks,
Mark
Great people talk about ideas; ordinary people talk about things; small-minded people talk about other people.
<a href="http://www.windowvideos.com">WINDOWVIDEOS.COM</a> - Ambient Video Experiences
headkaze
  • 0x2b|~0x2b?
Try a batch file, something like:
Code: [Select]
@ECHO OFF
:START
goldentee.exe
GOTO START
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
Years ago there was a "watchdog" or "daemon" service that would monitor a process and restart it if it died.  After several consecutive failures it would reboot the machine.  I just did a quick search and didn't see anything but what you're looking for does exist.
Search around "watchdog", "daemon", and "critical service monitoring."
dot
marknetwork
    • MarkNetwork.com
Code:
@ECHO OFF
:START
goldentee.exe
GOTO START
THIS WORKED PERFECTLY! THANK YOU SO MUCH!!!!! :)
Mark
Havok
  • Trade Count: (+17)
That doesn't fire off multiple instances of the executable?
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
If it does try this:
Code:
@ECHO OFF
:START
start /wait goldentee.exe
GOTO START
Bill Mote
It shouldn't.  If memory serves you can launch a process from a batch file with @call some.exe.  That will launch the .exe in a separate command process and continue your batch.  The batch as provided will launch the game and won't continue to the next step until the .exe is done (or crashed) ;)
dot
