Author Topic: Bug in WinCab?  (Read 4705 times)
JustMichael
  • Mmmmm!! Cheesecake!!
Bug in WinCab?
« on: October 27, 2006, 07:36:46 pm »
I am running XP.  I tried changing my keyboard to "United States-Dvorak" in the "Regional and Language Options" of the "Control Panel".  Every other program acts just fine (sees the proper keys) but WinCab still sees it as a "QWERTY" keyboard.  Any ideas why?
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: Bug in WinCab?
« Reply #1 on: October 27, 2006, 07:45:18 pm »
Try this: UnZip the attached file into your jukebox directory and add the following to jukebox.ini:
Code: [Select]
[system]
keyboard = dvorak
Does that help?
--Chris
JustMichael
Re: Bug in WinCab?
« Reply #2 on: October 27, 2006, 07:55:38 pm »
WinZip says it is not a valid archive.  So does WinRAR.
Chris
  • Moderator
Re: Bug in WinCab?
« Reply #3 on: October 27, 2006, 08:00:27 pm »
Odd.  My WinZip opens it.  That one was created with XP's built-in ZIP capabilities.
This one was done with WinZip.  Tell me if it works...
--Chris
JustMichael
Re: Bug in WinCab?
« Reply #4 on: October 27, 2006, 08:53:22 pm »
Strange...downloads corrupt in Firefox (cuts off early each time) but downloads ok with IE.
Tried adding
[system]
keyboard = dvorak
to the jukebox.ini, then to the skin's ini and no luck with either.
Chris
  • Moderator
Re: Bug in WinCab?
« Reply #5 on: October 28, 2006, 03:25:00 pm »
Ah.  I should have expected that.  I'm reading the keyboard at too low a level; this is what allows me to see Shift and Alt as keys and not modifiers. Hmm.  I'll have to work on it.
--Chris
