Author Topic: Joystick not scrolling Mala menu?  (Read 24589 times)
loadman
  • Moderator
    • MaLa
Re: Joystick not scrolling Mala menu?
« Reply #40 on: February 07, 2008, 05:29:11 pm »
pretty please could you pull that thumb out :) its the only thing that annoys me about mala, you were 99% there with that last file you put out, just the scroll 2 games at a time that was wrong. :):)
 ;D  I know, I have to finish my first batch of JukeBox Plugin's too!    :dizzy:
loadman
  • Moderator
    • MaLa
« Reply #41 on: February 22, 2008, 09:34:00 pm »
I'm taking a break from my work on a JukeBox Plug-in to crack this nut..
I gotta be close right   :o
thefunkygibbon
  • Last login:July 28, 2008, 06:26:53 pm
« Reply #42 on: February 23, 2008, 12:51:29 pm »
wooo!! :D cant wait.
fisk
  • Last login:July 01, 2008, 01:58:47 pm
« Reply #43 on: April 24, 2008, 09:24:41 am »
I am having the same problem on my cocktail cab.  Mala is great especially for the rotate screen feature for cocktail owners.  However the up and down keys not scrolling is definitely an issue.
Loadman you mentioned that you were almost there with a patch...has any progress been made.
Any help is appreciated.
All the Best
loadman
  • Moderator
    • MaLa
« Reply #44 on: April 24, 2008, 09:41:27 am »
Yep.
But the plan has changed
It won't be a Plug-in, It will be an additional option to the main MaLa code.  ;)
fisk
« Reply #45 on: April 24, 2008, 10:33:44 am »
That is good news...any idea when this might be availible...
Necro
  • Last login:November 29, 2022, 08:22:22 pm
« Reply #46 on: September 09, 2008, 09:44:47 pm »
*Bump* for a little suggestion to please add this to MaLa.  It's much needed...well...for me at least.
loadman
  • Moderator
    • MaLa
« Reply #47 on: September 10, 2008, 03:12:27 am »
No need to bump.  ;)
It's on the list
I do what I can for MaLa when I can  :)
Necro
« Reply #48 on: September 10, 2008, 08:42:07 am »
There is a way to get around this issue that I discovered last night using Autohotkey.  Once I get home this evening I'll post the script code for it (it's very basic) to essentially make it function properly in FrontEnds while still working correctly in emulators.
loadman
  • Moderator
    • MaLa
« Reply #49 on: September 13, 2008, 07:43:40 pm »
