Author Topic: OK screens  (Read 5718 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
OK screens
« on: October 22, 2006, 07:15:34 am »
Could anyone be so kind to tell me the way to remove all OK screens in the latest versions of MAME32? The old way of replacing a couple of lines in mame.c no longer works. It's for my personal use and I will not distribute my build. If you think this information should not be public, please send me a message to stormrider@alvarezeninternet.com. Thanx in advance.
MartyNg
  • Last login:April 26, 2014, 11:37:48 am
Re: OK screens
« Reply #1 on: October 22, 2006, 09:21:12 am »
I'm running MAME 106, and I dont' mind the disclaimer junk, but when I have parties and everyone's crowding around the machine, I always have people asking me if I can turn that off. I think I'd rather see a 5-minute disclaimer screen the first time I boot up the cabinet instead of having it every time a game starts up!
SirPeale
  • Green Mountain Man
Re: OK screens
« Reply #2 on: October 22, 2006, 10:30:41 am »
You can turn it off in mame.ini.
You'll always get game info the very first time you run a game, but it doesn't come back after that.
Gradius
Re: OK screens
« Reply #3 on: October 22, 2006, 12:29:07 pm »
It must be this line in mame.c:
ui_display_startup_screens(!settingsloaded && !options.skip_disclaimer, !options.skip_warnings, !options.skip_gameinfo);
Unfortunatelly I have no idea of C, so I don't know how to edit it. If I remove the '!' I skip the OK screens but I have a screen showing the game information, which promts you to press the select key. It's a step forward, but not the real solution.
Gradius
Re: OK screens
« Reply #4 on: October 22, 2006, 12:35:51 pm »
I GOT IT! This is the right line of code! -->
ui_display_startup_screens(!settingsloaded && options.skip_disclaimer, options.skip_warnings, !options.skip_gameinfo);
headkaze
  • 0x2b|~0x2b?
Re: OK screens
« Reply #5 on: October 22, 2006, 01:31:21 pm »
Yep, or add the following line above ui_display_startup_screens()
Code: [Select]
/* ensure we don't show the opening screens at start */
options.skip_disclaimer = options.skip_warnings = options.skip_gameinfo = TRUE;
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
Re: OK screens
« Reply #6 on: October 23, 2006, 05:21:15 am »
I am running the command line version of Mame 1.09.  Where could I go and do this for the warnings (100% video emulation....)
John
Galaga... Was there any other game?
berlincam86
  • Last login:January 30, 2020, 10:03:28 am
  • I can't wait to build my first cabinet!
Re: OK screens
« Reply #7 on: October 23, 2006, 07:20:53 pm »
could you guys help me? Im running mame32fx 108. where do you put that command line i dont understand where you guys put it in C ? :dunno
« Last Edit: October 23, 2006, 07:24:03 pm by berlincam86 »
headkaze
  • 0x2b|~0x2b?
Re: OK screens
« Reply #8 on: October 23, 2006, 07:38:36 pm »
You have to set up the MinGW compiler environment in order to compile mame. Check out Mr Do's Compiling Mame for Dummies. Quite often it's as simple as getting the latest source for Mame, then over writing the Mame32 or Mame32FX source or whatever version you want to compile.''
You have to go into src\mame.c and add the following line before ui_display_startup_screens()
Code: [Select]
Then you need to compile (make) the new version. Say you have a Pentium 4 and want to compile Mame32 with the UI then compile with:
Code: [Select]
mingw32-make.exe WINUI=1 P4=1 NAME=Mame32P4
berlincam86
Re: OK screens
« Reply #9 on: October 23, 2006, 08:20:54 pm »
Please im new at this i dont understand one bit of this could you possibly explain this step by step. Im sorry for the trouble. I got  the mingw file in my mame 32 file but i dont know what to do next.
berlincam86
Re: OK screens
« Reply #10 on: October 23, 2006, 08:26:58 pm »
ok I didnt read the rest of that page i will read that first then get back to you.
berlincam86
Re: OK screens
« Reply #11 on: October 23, 2006, 09:11:37 pm »
ok im a real dummy because i tried that and i dont know what i did wrong but i cant get it to work.
Zeosstud
  • Last login:December 01, 2025, 07:27:46 pm
Re: OK screens
« Reply #12 on: October 26, 2006, 11:12:57 am »
If  your still stuck let me know, I will help you.
Zeosstud
butlerrodney@hotmail.com
berlincam86
Re: OK screens
« Reply #13 on: October 26, 2006, 08:01:24 pm »
I have added you to my msn messenger list I really need help with this.
berlincam86
Re: OK screens
« Reply #14 on: November 04, 2006, 05:45:37 pm »
Im still stuck please help!
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Re: OK screens
« Reply #15 on: November 05, 2006, 12:19:00 pm »
So that people can help you out, tell us what you are doing and what error messages are being produced please.
berlincam86
Re: OK screens
« Reply #16 on: November 05, 2006, 01:29:05 pm »
Im trying to compile mame to remove the ok screens but i cant figure out how setup the mingw program.
Zeosstud
Re: OK screens
« Reply #17 on: November 07, 2006, 01:28:00 pm »
I believe this problem had been taken care of.  Not to worry.
Zeosstud
berlincam86
Re: OK screens
« Reply #18 on: November 07, 2006, 06:28:21 pm »
Yes i have got it thank you.
Buddabing
Re: OK screens
« Reply #19 on: November 07, 2006, 06:42:58 pm »
Just put two buttons on the edge of the control panel, label one "O" and the other one "K". What's the problem?
Please read the wiki!
berlincam86
Re: OK screens
« Reply #20 on: November 07, 2006, 07:05:44 pm »
just didnt want to push any buttons.besides start that is.
trcroyle
  • Last login:December 05, 2007, 10:32:05 am
Re: OK screens
« Reply #21 on: November 10, 2006, 06:29:49 pm »
Happ is all out of "K" buttons and ponyboy won't answer my PMs!
AlanS17
    • AlanS17
Re: OK screens
« Reply #22 on: November 11, 2006, 07:55:57 pm »
I mounted mine inside the coin door.
FrizzleFried
    • Idaho Garagecade
Re: OK screens
« Reply #23 on: November 12, 2006, 01:28:44 pm »
How friggin' hard is it to move a joystick back and forth?
(that coming from a guy who remapped his EXIT from P1-A to a single button...same with credits for P1 & P2)...
berlincam86
Re: OK screens
« Reply #24 on: November 12, 2006, 07:18:14 pm »
with a cabinet that only has a lightgun its pretty hard.
diverdown
  • Last login:April 21, 2025, 03:45:48 am
Re: OK screens
« Reply #25 on: November 12, 2006, 10:21:28 pm »
lol
try wiggling the gun
If it ain't broke give it to me...i'll soon fix that
berlincam86
Re: OK screens
« Reply #26 on: November 13, 2006, 07:56:35 am »
lol yea maybe that will work.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: OK screens
« Reply #27 on: November 13, 2006, 03:56:38 pm »
It will if you remap the lightgun to (also) "UI right" and "UI left".
Robin
Knowledge is Power
