Author Topic: ActLabs - MAME - Readl Arcade RGB Monitor? Only works outside of MAME  (Read 3715 times)
P-r0t
  • Last login:March 25, 2003, 08:49:02 am
  • On my third cabinet already :D
Hi
I'm trying to get this Act Labs usb game gun to work on with my mame cabinet setup.
I'm using the following:
Real arcade RGB monitor.
ArcadeVGA agp card from ultiimarc
Windows XP (sigh.... only went XP for gun compatibility)
P4 2.2Ghz 512DDR ram.
I made the appropiate changes in the mame.ini
lightgun 1
Now heres the tricky part. The gun will work with the windows based games/web based games Act Labs has provided, but not while inside mame.
I chose "point blank" as a game to test with. The game loads and 2 cross hairs appear. After I caliberate the gun I'm able to get one shot off, usually points the P1 cross hair to the bottom left of the screen. After that no more shots are accecpted.
Has anyone seen activity like this?
any help would be greatly appreciated!
thanks!
-P-r0t
Anonymously
  • Last login:May 26, 2005, 02:13:11 am
  • MarMags Arcade
Re:ActLabs - MAME - Readl Arcade RGB Monitor? Only works outside of MAME
« Reply #1 on: March 24, 2003, 10:41:11 pm »
Is the Hardware streaching enable or not?
No Offense, it's just a suggestion
P-r0t
« Reply #2 on: March 25, 2003, 08:50:58 am »
Hi,
Thanks for the reply.
No hardware stretching is disabled. Does this need to be enabled for the gun to work ? Also, a bit off topic, but is there a way to enable HW stretching without the filtering effect? I prefer the natural look :)
P-r0t
pocketz
  • Last login:June 28, 2004, 10:42:03 pm
  • INSERT COINS
    • arcade addiction
« Reply #3 on: March 25, 2003, 06:00:58 pm »
my act labs light gun works in mame with my 27" wellsgardner vga arcade monitor. if you havent already, theres a setting to turn on the light gun in mame...
in mame, click options, then default options, then click enable light gun input.
also, try using the gun in an exidy game like chiller or who dunit. those games are the ones i play and they work fine, ive tried playing some of the nintendo playchoice-10 light gun games and they didnt work correctly.
other than that i dont know what could be the problem.
-pocketz
« Last Edit: March 25, 2003, 06:05:31 pm by pocketz »
P-r0t
« Reply #4 on: March 26, 2003, 08:57:55 am »
hmm I'll give the tab menu a shot. I had thought that enableing it in the config file would have worked, but hey if this works i won't complain :)
Thanks for the tip!
-P-r0t
 :o
Chris
    • Chris's MAME Cabinet
« Reply #5 on: March 26, 2003, 09:04:44 am »
Try Sharpshooter as a test game.  It seems to be the easiest and most accurate with the Act-Labs gun.
--Chris
--Chris
P-r0t
« Reply #6 on: March 26, 2003, 08:34:26 pm »
well i didn't think it would make a difference, but it apparently did. Enableing hardware stretching WORKED!!! but sadly I don't like the blurry look on the cabinet, almost defeats the purpose.
Also the gun appears to be horribly inaccurate! the grey calliberation screen doesnt come up with hw stretching enabled but for the most part its accurate except for games that require a reload and point off screen... that part takes about 10 or so tries to work.
It also might be the think piece of plexi glass i have in front of the monitor. I'll try it later tonight with it removed.
For the most part I've heard good feedback about this gun, so I'll assume that either my gun is defective or it simply doesn't like my monitor.
if anyone's intersted i have a Sharp 26" monitor in this pirticular cabinet.
P-r0t
Chris
« Reply #7 on: March 26, 2003, 08:40:22 pm »
There's a patch to MAME that fixes the shoot offscreen and reload bug. I've applied it and it works perfectly.
The gun's calibration calibrates it to the actual full screen, so if your image doesn't fill the screen, the gun will be accurate near the center but off near the edges.  If the grey calibration screen doesn't come up, the gun certainly won't be accurate.  My grey calibration screen does come up with hardware stretch on...
--Chris
--Chris
Zinfari
  • Last login:August 15, 2007, 10:43:59 am
« Reply #8 on: March 26, 2003, 08:45:15 pm »
You may have already read this on the Ultimarc site, but in the forum over there is a thread going regarding this.  Sounds like they are having mixed results.  Maybe they will have some tips.  In looking over the threads I haven't seen anyone with XP run it successfully, but not everyone is posting their specs.
http://www.ultimarc.com/wwwboard.html
Oh yea and here was another thread here regarding this issue.
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=4949
Good Luck,
-Zinfari
« Last Edit: March 26, 2003, 08:49:37 pm by Zinfari »
P-r0t
« Reply #9 on: March 27, 2003, 10:42:16 am »
Hmm intersting news!
Thanks for the replies, any chance you can point me to the location to that mame light gun patch? i checked on mame.net and didn't see it as an official download.
P-r0t
Chris
« Reply #10 on: March 27, 2003, 11:12:11 am »
It's not official, but I just posted it in another thread at http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=6017;start=0#lastPost .  Of course, you have to recompile MAME to install it...
I have it compiled for MAME .65, but .66 requires DJGPP 3.0, and there are other things I can't compile with 3.0, so MAME .65 is the end of the line for me for a while...
--Chris
--Chris
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: March 28, 2003, 07:22:25 am »
It's in Mame:Analog+ if you don't want to compile, and works for both Area51 and MaximumForce.  see sig
Robin
Knowledge is Power
P-r0t
« Reply #12 on: March 28, 2003, 10:01:23 am »
kick ass!
thanks i'll try this tonight !  :D
P-r0t
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #13 on: March 28, 2003, 04:31:35 pm »
Change the effect setting to 'sharp', doesn't look as blurry.
Anonymously
  • MarMags Arcade
« Reply #14 on: March 30, 2003, 12:24:56 am »
Hmmn tom61 How do you do that with Hardware streaching?
StephenH
« Reply #15 on: March 31, 2003, 02:45:32 am »
It could be that your monitor is 15Khz and the guns were designed for true VGA or SVGA (31Khz or higher).
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #16 on: March 31, 2003, 04:40:58 am »
load up yer mame.ini file and look for the line 'effect        none' (may be set to something else if you've enabled scanlines or something) - simply change it to sharp to get a better image
 :P
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
Chris
« Reply #17 on: March 31, 2003, 01:41:06 pm »
I thought all the effects were disabled when hardware stretch was active... ???
--Chris
