Author Topic: Griffin Powermate  (Read 2099 times)
raremind
  • Last login:April 22, 2003, 08:18:28 pm
  • Live for Arcade
Griffin Powermate
« on: March 24, 2003, 02:45:28 pm »
I just purchased the Griffin Powermate to use as a spinner. Thing is I cant get to to work in mame32, anyone out there get this gizmo to work at all. Please let me know.
hyiu
    • www
Re:Griffin Powermate
« Reply #1 on: March 24, 2003, 02:49:32 pm »
I also got one before....
and tried it with Mame32 v 61 in Windows...
couldn't get it to work.....
well... it works... but it goes too slow....
I rotate the powermate a full circle and it only goes a little...
have tried to change the setting / sensivity... but not much improvement.... (also updated drivers also...)
so... finally.... returned it... if you can get it to work, plz post details.... thx.... good luck...
raremind
  • Live for Arcade
« Reply #2 on: March 24, 2003, 03:29:32 pm »
I cant get the thing to work at all, It will not even move a little with full spins. I also set the click to press the number 5 to add credits and that does not even register. I works great with word. Press down it types a 5 rotate left right works great, but will not work in mame. I think I just might return it too.
hyiu
    • www
« Reply #3 on: March 24, 2003, 10:15:14 pm »
if you're using Mame32, you'll need to go to options... and check that mouse input box in the controller section...
then just use the powermate as a mouse and it should work... (well... it works like you turn and it moves a little...)
but I couldn't get it to move fast enough to play like arknoid...
good luck...
if it still doesn't work, try go to powermate site and download their newer driver... I believe they have a newer driver in their website....
ps: for your info, I was using Windows Me with Mame32 V.61
good luck to you...
if you can get it to a playable state, plz let us know... I'm interested.... cos it does look very cool...
_Iz-
  • Last login:December 03, 2025, 11:55:42 pm
  • Time to coin up!
« Reply #4 on: March 25, 2003, 07:15:13 pm »
I think the problem with the powermate is it sends emulated keystrokes not analog data making it not very appropriate for use as a spinner...
I had looked at it myself, it's a very cool piece of hardware...
