Author Topic: Mala and Ultimarc Ultrastik  (Read 5823 times)
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« on: October 16, 2006, 06:37:14 am »
Is there a way in Mala to switch the Input Map on the Ultrastick to the correct mapping upon selecting a game from a gamelist?  If so, what is the process of setting this up?  I did some light searching on the boards and couldn't find anything right off the bat.
Thanks for any insight you have on this.  I really like Mala and am considering rethinking my original P360 decision.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
Re: Mala and Ultimarc Ultrastik
« Reply #1 on: October 16, 2006, 06:52:03 am »
You can use the so called encoder programming for this purpose.
Enable and configure it on options->controller->encoder and then configure the MAME options on the tab MAME config->encoder.
If you use a game based programming of the stick and no config file for the game (romname.ext) is found MaLa will use the default config file for MAME/this emulator.
« Last Edit: October 16, 2006, 06:55:32 am by swindus »
csa3d
« Reply #2 on: October 16, 2006, 07:41:20 am »
Good to know!  So sounds like there's some manual "doings" to create the config per game.  Once that's done it's smooth sailing?
fatfingers
  • Got UltraStiks?™
« Reply #3 on: October 16, 2006, 09:55:19 am »
Interesting.  Could you help a poor soul out with a little more detail on how I would do this?  Also, is there a way to make it set the controller settings back to something sane like 4-way after exiting the game?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
csa3d
« Reply #4 on: October 18, 2006, 12:51:51 am »
I haven't even purchased a stick yet, so I'm not completely sure how the whole thing works.  I was curious as to what happens if I am in 4 way mode, then I switch to another emulator (like NES) that needs 8 way mode.  How does that work?  I suppose I need to configure some default per emulator.  This is probably completely obvious once you actually buy the stuff and mess around.  Guess that's what I get for trying to speculate ;)
swindus
« Reply #5 on: October 18, 2006, 05:12:15 am »
Right, you create a config file for every emulator and/or game. And you create a config file for MaLa which is loaded when you quit an emulator.
When you start a game and use game files MaLa will try to load the file for the started gamed. If this file is not found MaLa will use the emulator file instead.
loadman
  • Moderator
    • MaLa
« Reply #6 on: October 18, 2006, 07:15:57 am »
