Author Topic: 1957 Rock-ola 1455 Skin with mech sound effects  (Read 11232 times)
xk
  • Last login:July 09, 2025, 05:18:37 am
« on: October 13, 2006, 09:45:42 pm »
Just for anyone who isn't sure,you need to
download the file then unzip it and then copy the 3 files into your skin folder
Then edit the jukebox.ini file in wincab so the skin line reads
Skin = Rock-ola
Skin based on a real jukebox and includes sound effects of the mechanism
selecting the record and then playing it.
Download the zip file here.
http://www.mediafire.com/?519gzgymy2b
http://www.savefile.com/files/204380
« Last Edit: July 04, 2007, 09:02:43 am by xk »
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: 1957 Rock-ola 1455 Skin with mech sound effects
« Reply #1 on: October 14, 2006, 02:08:50 am »
I'm gonna have to use this one as an example when I get animations working!  I need to see if I can find a video of this in operation to create the animations...
--Chris
xk
« Reply #2 on: November 25, 2006, 05:22:10 am »
Added some more sound effects for the selection buttons.
To install,Copy the wav sound files in the Buttons Zip to the SKINS folder of Wincab.
Then open the rock-ola.skn with
notepad and add the following text to the
[Sounds] section:
BTN_A=but2.wav
BTN_B=but2.wav
BTN_C=but2.wav
BTN_D=but2.wav
BTN_1=but2.wav
BTN_2=but2.wav
BTN_3=but2.wav
BTN_4=but2.wav
BTN_SELECT=but4.wav
BTN_CLEARQUEUE=but4.wav
BTN_GUI_SELECT=but4.wav
BTN_RADIO=but3.wav
BTN_RANDOM=but.wav
BTN_SKIPLAST=but3.wav
BTN_SKIP=but3.wav
BTN_POPULAR=but.wav
You also need to change the following line in the "VolumeControl Section" of the Jukebox.ini file.
SoundEffectsVolumeWhenPlaying=0
Change to
SoundEffectsVolumeWhenPlaying=65
