Author Topic: What would the minimum CP be for this?  (Read 36839 times)
fredster
  • It's all good!
« on: October 09, 2006, 03:50:00 pm »
What would the most minimum control panel necessary to run this?
I am trying to figure this software out, but I'm trying to see if you could get by with like 5 buttons and no mouse.
If you were to design a CP that is the bare bones, what would it be?
BobA
  • What Me Worry?
Re: What would the minimum CP be for this?
« Reply #1 on: October 16, 2006, 06:39:59 pm »
Cannot see it working without at least a number pad.  Does not seem to go well with limited arcade controls.  A trackball would work if you don't want a mouse hanging around then you would not need a number pad.
My min is a touchscreen with no external buttons.
« Last Edit: October 16, 2006, 06:42:52 pm by BobA »
Freeplay
  • Last login:May 02, 2015, 06:04:19 pm
  • I'll be crosses !
« Reply #2 on: March 26, 2007, 06:01:41 am »
I run my jukebox with 10 buttons on the control panel..... and 1 hidden button for admin.
"The Best Thing About Getting Old"
You can afford bigger and better toys
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #3 on: March 23, 2013, 12:53:52 pm »
i'm building a minimal wall hung skjukebox with the following.
credits button - to add credits
right button - slide albums right
left button - slide albums left
down button - to highlight a song when in large album mode
enter button - to add highlighted song to que
esc button - to return to 4 album view
f1 button  to toggle large album mode.
if you disable mouse support the down arrow can select a song when in large single album mode.
the enter button selects it and the song is added to the cue.
you can also do without the credits button if you enable free play. also the esc button is not needed because 4 album view returns by itself after some time.
I just use a 4 way joystick and two buttons.
