Author Topic: ArcadeOS/ADVMame issues  (Read 2924 times)
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« on: October 09, 2006, 03:43:41 pm »
I'm hoping someone can help me out here. I have used the Fraggal boot disc to se up my dos-based cab computer and I am having a hell of a time trying to upgrade to newer versions of ADVMame. The disc includes ADVMame 0.62, and I can upgrade a version or two beyond that, but can not get any of the newer versions to work. Can anyone give me a helping hand with this? What is the newest version of ADVMame you are using with ArcadeOS 2.52?
Thanks,
James
www.wolfelectronics.ca
Cap Kits for Canadians!
Grauwulf
  • Button Masher
Re: ArcadeOS/ADVMame issues
« Reply #1 on: October 11, 2006, 05:47:32 pm »
Is no one using this setup anymore?
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« Reply #2 on: October 11, 2006, 09:25:33 pm »
Sory I can't actually help
I have been using a disc called Darren's Setup Cd.........  It is a little diferent as it is not setup to run on an arcade monitor (well i dont think it is) and ther are none of the video config options at startup. otherwise it seems exactly the same.
There is a update mame option  but Im not sure how to do it. i would like to know how exactly it is done.  How have you done it with fraggle?  i know you are stuck but at least you know your stuck.
If it ain't broke give it to me...i'll soon fix that
Grauwulf
  • Button Masher
« Reply #3 on: October 11, 2006, 11:59:57 pm »
Basicaly I am just copying the newer versions of AdvanceMAME into the mame directory and then running the ADVCGG.exe program to make sure the config is right for that version of mame.  When I go back into ArcadeOS and try to run a game I get error messages.
Grauwulf
  • Button Masher
« Reply #4 on: October 13, 2006, 08:31:51 pm »
Okay, I ran Advancemame from a command prompt and the error I am getting is (for 1943) Error parsing event database for 1942b
So ADVmame isn't even working from the command prompt
So.....I need to fix that problem first. I have googled and searched, but came up dry.
Grauwulf
  • Button Masher
« Reply #5 on: October 14, 2006, 06:26:18 am »
Okay, I think I mostly have this sorted out now. I deleted my etire mame directory and started from scratch. Put a fresh install of ADVMAME 0.96 on, tried to run it, won't process the rom list. Hmmmmmmm. Drop a copy of DosMAME in to the directory with it and volia! it works! So it looks like the problem all along was my ADVMAME installation. Too bad I managed to trash my working ADVMAME.RC file in the process. Take one step forward, take one step back. *lol*
