Author Topic: Can you run MDF through a planer  (Read 5209 times)
mlcampbe
  • Last login:December 08, 2022, 10:54:49 am
« on: October 09, 2006, 03:40:38 pm »
Since I am unable to find 5/8" MDF locally I want to try running my CP made out of 3/4" MDF through a planer to reduce it to 5/8" but am concerned that it will make a mess of it.
Anyone got any experience with running MDF through a planer successfully?
nullb0y
  • Slow In Fast Out
    • WAT Racing
Re: Can you run MDF through a planer
« Reply #1 on: October 09, 2006, 04:49:16 pm »
try a test peice first.... / why not just use the thicker wood or make the cp out of other materials
Slow In Fast Out
mlcampbe
« Reply #2 on: October 09, 2006, 05:07:15 pm »
I made a sample CP out of the 3/4" material planning on buying 5/8" later on and adding a 1/8" piece of plexi over it. However, the 3/4" panel came out very clean and also I am having trouble finding 5/8" MDF too.
If I use the existing 3/4" and add a 1/8" piece of plexi then my t-molding won't line up properly.
prOk
  • Last login:December 28, 2015, 08:29:34 pm
  • www.rgvac.com
    • Brian's Classic Arcade
« Reply #3 on: October 09, 2006, 07:14:31 pm »
mdf will dull your planer knives quickly... and the planed side will have a fuzzy texture that only some 400 grit sanding will fix.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #4 on: October 11, 2006, 09:40:55 am »
You can do it, but it plays hell on planer knives.
I would router a Rabbet 1/8" deep around the bottom of the CP. This will allow the bulk of the material to be 3/4", but the edge you see with T-molding on it will look like it is 5/8" material with 1/8" plexi. Knievel uses this technique all the time on his builds. You might peruse a few of his threads for details.
« Reply #5 on: October 12, 2006, 11:54:15 am »
That's a fantastic idea!
