Author Topic: do I need the mame resolution tool?  (Read 1047 times)
Sizzler
  • Last login:January 25, 2008, 12:28:46 am
« on: October 05, 2006, 09:45:27 pm »
Is the mame resolution tool for arcade monitors or computer monitors?
It seems like a tool that might help me but there isn't much of an explanation of what it would do for me.  Do I need automatic and manual selection of resolutions?
http://mamewah.mameworld.net/downloads.htm
Here is my imaginatively titled M.A.M.E. Resolution Tool, for automatic (& manual) selection of resolutions & INI file creation.  Click here to see it in action.  Note the above system files are required for this to run.  Simply download the zip-file and unzip to your chosen location.
Download M.A.M.E. Resolution Tool v2.0! (56KB)
MYX
    • MYX Digital Blog
Re: do I need the mame resolution tool?
« Reply #1 on: October 06, 2006, 08:00:48 am »
It is for folks using an arcade monitor using a video card that will produce lower scan rates n resolutions.
There is not much about it and using it at first is a little bit of a pain. Once you get to know it better it works very well. But you will probably  :banghead:  for a while.
M    Y    X
