Author Topic: Donkey Kong 3 monitor showing gibberish  (Read 3739 times)
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« on: October 05, 2006, 02:05:20 pm »
I'm not sure if this is the best forum to post this in but in the past it has been the most helpful.
I recently purchased this DK3 machine and restored it to a DK original.  This can be seen here http://forum.arcadecontrols.com/index.php?topic=57623.0
On one of the pictures in that topic, (and attached below) you will see what the monitor is showing on bootup.
Little history.  Mike's Arcade has shopped this board in the past.  The seller said when he received it back it showed on the screen as seen in the picture.  He emailed Mike's arcade and Mike said that it could be the power supply.
I, just yesterday, checked the power supply output and replaced some shady looking resistors on the PCB.  I still receive the same output on the monitor.  Gibberish.
Where should I focus my attention?
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
Re: Donkey Kong 3 monitor showing gibberish
« Reply #1 on: October 05, 2006, 04:17:06 pm »
was the voltage low?
Lutus
« Reply #2 on: October 05, 2006, 04:23:36 pm »
No, did not appear to be.  I will recheck but no it wasn't low.
5 volts showed as 5.12 or something like that.  Each was very close.
grantspain
« Reply #3 on: October 05, 2006, 04:37:18 pm »
looks like eprom/graphic ram/general i.c failure or interboard connection problem to me
Lutus
« Reply #4 on: October 05, 2006, 06:10:26 pm »
One of the chips looks like the heatsink has come off of it and looks generally "shady".  I guess is the word.
cw
    • The Cab
« Reply #5 on: October 06, 2006, 08:16:02 am »
I did a little digging and found this note on mikes arcade
Problem: game plays but numbers instead of graphics fill the screen
Solution: replace bad 2114 RAM at 2P on the video board.
its listed as a fix for a dk junior but it might be the same pcb set.. still looking
Lutus
« Reply #6 on: October 06, 2006, 12:02:30 pm »
This guy used Mame and recreated a bad chip for all the chips on his DK board set.  Then he compared the image to see what chip was wrong.  Very interesting read and do you think this would be possible for DK3?
http://www.brasington.org/arcade/tech/dk/
Lutus
« Reply #7 on: December 18, 2007, 08:50:02 am »
Over a year later and I am back.  I won a DK3 board off of ebay and placed it in the machine last night and it works!!!
I then performed capkit surgery that I have been meaning to perform since... well, OCT 2006.  My new job has kept my schedule slammed.... but how many people get business travel to Hawaii for 3 weeks?   :laugh:
I will be troubleshooting the first board again, so will update again once that process is started.
