Author Topic: CHD games  (Read 2673 times)
sol
  • Last login:November 14, 2008, 03:27:04 am
CHD games
« on: October 04, 2006, 05:58:38 am »
Hello
Which processor would handle these the best
A Intel pentium D Dual Core 3.4 GHz/2x2mb cache
or a Intel core 2 Duo (fsb 1066MHz,2.4GHz, 4MB cache)
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
Re: CHD games
« Reply #1 on: October 04, 2006, 03:31:43 pm »
Sheesh, that's some serious beef to throw at a game so I'd get some winmark stats, just to get a baseline, but you should be able to run most things (standards) with no problem. I've seen kinst run pretty well on a Sempron 3200 so you're crushing that system. That said, it's rare to find anything else that works much at all
« Last Edit: October 04, 2006, 07:29:12 pm by releasedtruth »
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
Re: CHD games
« Reply #2 on: October 04, 2006, 04:20:17 pm »
     You won't be able to run 95% of the chd games. It is not a machine issue it is the emulator. I may be stating this incorrect from a technical standpoint but the jist of its meaning is the same. The MAME devs did not code mame to be playable but to be a replica of the arcade experience. A rule of thumb you need 10X the processor power that the original game used to play the game. I've seen this number used many a times on this very subject but to run the chd games you would need a 10ghz processor. That being straight processor power not multi processors or multi-threaded processors as MAME does not utilize multiple processors.
     So basically you're out of luck for now. If you'd like a better explaination search the site as there are a lot of threads on this very subject and those that know have answered with more technical mumbo jumbo than I just have...
The Way Back Machine - http://www.taborious.com
vorghagen
  • Last login:September 05, 2017, 01:06:59 am
Re: CHD games
« Reply #3 on: October 04, 2006, 07:51:27 pm »
Although that is usually the case with MAME games and processing power needed, I'm sure I've seen some of the newer CHD games run fairly smoothly on a mid-range system.
There could have been other factors (eg. running optimized mame code, frame skipping, other tech stuff I don't understand etc) but it definitely can be done, at least with some games.
PS. I assume asking where to find CHD files comes under the same rule as ROM files... ie don't?
Never argue with an idiot, he'll just drag you down to his level and beat you with experience.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: CHD games
« Reply #4 on: October 04, 2006, 07:57:25 pm »
More like 60-80% ATM, depending on if you're including clones or just the parents, but who's counting?
Core 2 smokes the P4.  Check out the benchmarks at mame32qa.  A P4 is not included any more, though; it's too slow.  In past benchmarks at the same page, the a64 3400+ usually beat the P4 3.4 gHz, except for the games running on playstation-like hardware.  And the Core 2 is beating the A 3700+.
Robin
Knowledge is Power
sol
Re: CHD games
« Reply #5 on: October 04, 2006, 09:04:37 pm »
Thats excellent thanks for the help, it looks like the core 2 for me, I did't realise there was a 3GHz version.  :cheers:
krick
  • Gotta have blue hair.
Re: CHD games
« Reply #6 on: October 05, 2006, 01:14:27 am »
It's an overclocked 2.4Ghz chip.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
sol
Re: CHD games
« Reply #7 on: October 05, 2006, 02:02:52 am »
ok thanks
