Author Topic: Frontline spinner, someone asked for one?  (Read 3389 times)
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« on: September 30, 2006, 11:48:02 pm »
I'm pretty sure someone had asked me if I had a Frontline spinner, but I can't find the message.
To whomever it was:  I actually found one in my stuff last weekend.  Unfortunately, I forgot to bring it home to take pics.  Next time I go out there, I'll try to snag it.
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
Re: Frontline spinner, someone asked for one?
« Reply #1 on: October 01, 2006, 05:06:34 pm »
I was lookin' for one but changed my mind since the custom wiring job needed for MAME would be a beating for me.  :(
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« Reply #2 on: October 01, 2006, 05:32:09 pm »
PM Sent
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: October 02, 2006, 01:35:52 pm »
Custom wiring job?  I think it's exactly the same as wiring a joystick and fire button- or am I missing something?
Texasmame
  • Ba, ba, boom!
« Reply #4 on: October 02, 2006, 02:46:00 pm »
I recall something about a switch to cut the ground or something similar when you go to enter it as a control in MAME.  That's on the boards somewhere. . . :dunno
Rip
  • Last login:September 26, 2008, 05:28:16 pm
  • Product of the 80s
    • Curret lineup
« Reply #5 on: October 02, 2006, 03:11:35 pm »
Yep.  The frontline spinner is effectively an 8-way joystick (4 switches), but 1 or 2 of the switches are always activated depending on position.  The easiest way to "disable" the control (so that it doesn't always signal a switch closed) is to disconnect the ground as needed.  I have mounted a simple on/off switch on the ground wire which leads to the control under the control panel.  When I want to play frontline/wild western/tin star, I simply turn the switch on, otherwise it is left off for general pupose mame games.
Recreating the 80s, one cab at a time.
Gallery
Texasmame
  • Ba, ba, boom!
« Reply #6 on: October 02, 2006, 04:17:20 pm »
Actually, doesn't sound as bad as I remembered!
