Author Topic: Replacing monitor in SF2 Turbo  (Read 1955 times)
Jack Burton
« on: September 28, 2006, 04:30:24 pm »
Hi, I've got the opportunity to buy this machine for 100$:
http://www.klov.com/game_detail.php?letter=&game_id=9818
As far as I can tell it's the exact same cabinet as the image.
The monitor is dead, I don't really know why.
What would be the cheapest and easiest method to replace the monitor?  I don't really mind if I have to use a computer monitor or TV, I just want to be able to see the game.  I also don't care if the replacement monitor is a little smaller.
Crax
  • Hmm......maybe you should get that test still
  • Last login:March 12, 2022, 04:11:41 pm
Re: Replacing monitor in SF2 Turbo
« Reply #1 on: September 28, 2006, 04:36:31 pm »
I can't answer your question about the monitor, but for $100 I would definately get that.
SirPeale
  • Green Mountain Man
« Reply #2 on: September 28, 2006, 06:33:57 pm »
And don't automatically jump to replacing the monitor.  Most monitor repairs aren't that complicated.  And we can help here, that's what we do!
Jack Burton
« Reply #3 on: September 28, 2006, 08:36:16 pm »
thanks,
The owner tells me the monitor stopped working after the machine was left on during a lightning storm.
I suppose a power surge may have damaged it.
SirPeale
« Reply #4 on: September 28, 2006, 09:29:24 pm »
That can happen.
Could be a number of things.
Need to know the make/model of the monitor.  Post back here when you have that information, as well as the cabinet in front of you so we can begin the troubleshooting process.
First step: check fuses, and make sure the monitor is actually getting power.
grantspain
« Reply #5 on: September 29, 2006, 03:53:34 am »
during a storm the usual way a tv gets fried is when the lightning hits the aerial but as you have a cabinet not connected to anything bar mains socket the only thing that can happen is a power surge,thats likely to blow a fuse only because an isolation transformer takes most of the surge-i don't think its gonna be a big job getting this machine back online
Jack Burton
« Reply #6 on: September 29, 2006, 11:47:50 am »
So first I need to get you guys a picture of the monitor correct?  Or even better, the manufacturer.
Then I need to check to see if any fuses are blown.  I think I can do that.
Additionally, I can buy this machine for 75$.
http://www.klov.com/game_detail.php?letter=&game_id=6873
The monitor works but the game just displays garbage on power on.
Would I be able to swap parts between these two to create a working machine?
grantspain
« Reply #7 on: September 29, 2006, 12:02:12 pm »
both games run the same frequency monitor so you should be able to swap o.k
the one that comes up with garbage is probably low +5 volts/game board bad connection or eprom seating or game board i/c faulty
i think with this forum's help its possible to get both working(no promises though) :cheers:
JoshuaMiller
  • Last login:December 22, 2007, 08:14:18 pm
« Reply #8 on: October 07, 2006, 12:07:14 am »
I't been a while since your post, so I assume you've figured this out.
However, if you live anywhere near San Francisco, I have a sf2 Hyper fighting monitor that I'll sell you.
--Joshua--
