Author Topic: How does a Midway Wheel Driver Board work ?  (Read 2741 times)
Hantalex
  • Last login:September 29, 2006, 03:29:22 am
« on: September 26, 2006, 08:43:05 am »
Hi,
I recently got a California Speed Sitdown Racing Cab without pcb, so I decided to put my Xbox in there. I hacked a Fanatec Speedster 3 Wheel to the Steering-,Breaking- and Accelerating-Pots and it works really fine.
Looking through other Projects like Mark
« Last Edit: September 26, 2006, 09:00:48 am by Hantalex »
fredster
  • It's all good!
Re: How does a Midway Wheel Driver Board work ?
« Reply #1 on: September 27, 2006, 02:20:11 pm »
Triacs or SCR's are what are used to activate higher voltages from transistors and IC's.
Is the 36V AC or DC? What is the "motor?" Is it a relay?
Hantalex
« Reply #2 on: September 27, 2006, 03:57:14 pm »
The 36V is AC.
A wiring Diagram is available at tgma the game manual archive, see Cruisin exotica, it has the same wheel driver board as the one I have.
If you look at connector 8 there goes a ribbon cable to the game board. It
fredster
  • It's all good!
« Reply #3 on: September 27, 2006, 05:25:26 pm »
I dunno. I wouldn't think twice about trying to give it 12 V to kick it.
Hantalex
« Reply #4 on: September 27, 2006, 06:21:43 pm »
I
grantspain
« Reply #5 on: September 28, 2006, 06:45:07 am »
of course it won't(is that 12v a/c or d/c),if its a/c you could put some sort of transformer to get 36v(but you would need to put some sort of protection circuit or fuse inline with the output 12v)
I
Hantalex
« Reply #6 on: September 28, 2006, 02:03:46 pm »
I guess just pulling the 12v through a transformer will blow the power supply of the fanatec wheel.
Is there a way to make a simple circuit to check if the 12v are on or off and then release the 36v from the cabinet
grantspain
« Reply #7 on: September 28, 2006, 03:35:39 pm »
i reckon your new steering wheel outputs d/c voltage-you need to prove that first with a multimeter before you do anything else otherwise your gonna blow the poo outta something
lkench
  • Last login:August 06, 2014, 04:53:43 pm
« Reply #8 on: September 28, 2006, 09:34:39 pm »
