Author Topic: Mini Ipac question  (Read 1818 times)
sealslayer
  • Last login:March 18, 2014, 04:41:30 pm
  • Why screw when you can bolt
Mini Ipac question
« on: September 24, 2006, 09:10:24 am »
I have ordered my Buttons, Joysticks and trackball from dreamarcades and as we speak they should be crossing the pond over to me in the UK  :applaud:
My question is will a mini Ipac have enough inputs for my needs?
I will have two joysticks, with 6 buttons each, player 1 and 2 buttons, coin1 and 2, escape and maybe a tab button.
The trackball is PS/2 so theres no issue there I presume as that goes into my mouse slot.
cheers
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
Re: Mini Ipac question
« Reply #1 on: September 24, 2006, 09:51:00 am »
the minipac is ok but the wiring harness that comes with it is meh.. yep, meh. I have used it 4 times and the connectors dont reallly fir the microswitches. best to make your own harness.
sfrascella
  • Last login:September 21, 2017, 09:44:15 pm
« Reply #2 on: September 24, 2006, 11:03:57 am »
I have a similar setup on my CP and the Minipac does the job quite well. In my opinion the wiring harness is a must as it will save you lot's of time stripping and crimping. Also consider getting the extension pack if you have your controls more than 18" apart.
Texasmame
  • No, no. He's in charge here.
  • Last login:February 18, 2022, 05:28:39 pm
  • Ba, ba, boom!
« Reply #3 on: September 24, 2006, 11:33:49 am »
The review is here, with my comments/experiences at the bottom of the thread.
http://forum.arcadecontrols.com/index.php?topic=56820.0
londonbabe
  • Last login:June 06, 2007, 09:24:45 am
« Reply #4 on: September 24, 2006, 02:53:12 pm »
Yes, it will be fine for those inputs, and does an excellent job. Well worth the money.
I had to squish the crimp connectors a bit to get them to fit snugly, but hell, I had to do that on all the rest of my wiring too.
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #5 on: September 24, 2006, 08:14:18 pm »
Sounds like you will be needing 26 inputs, the Mini-Pac has 28, so your good to go.
Word of advice, GET THE OPTIONAL WIRE HARNESS, I bought my Mini-Pac without the optional $10 wire harness because I thought since I've wired a I-Pac4 before I was more then capable.......WRONG!
The Mini-Pac is just that....MINI! The pins are so close together that you need a special sized molex just to mate it to the wires.
Save yourself some time, it's only around $10-$12 with the Mini-Pac, well worth it.
Enjoy and Good Luck!
sealslayer
« Reply #6 on: September 25, 2006, 11:28:54 am »
Great, thanks guys  :cheers:
