Author Topic: Should I at least see a picture at 60 khz on arcade monitor?  (Read 1667 times)
Panzer
  • Last login:December 05, 2008, 08:04:25 pm
« on: September 23, 2006, 11:14:09 pm »
So I bought a video card that does not fit into my computers slot. (sorry about the terminolgy, or lack there of of)But I do have a VGA out that is at 60 KHZ. So I slpiced my VGA cable and my Wells K7000 series cable together and now at least see some color change on the arcade monitor but there it is still just a garbled mess even when I play with the adjustments.
My question is, I know I can't run the monitor at 60khz for to long or the monitor goes pop, But to test my cable shouldn't I at least being seeing some semblance of a picture, or does it HAVE to be output at 15khz?
Thanks guys!
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
Re: Should I at least see a picture at 60 khz on arcade monitor?
« Reply #1 on: September 23, 2006, 11:46:25 pm »
An easy way to test your cable is to download Powerstrip and try the arcade preset or similar 480i modes.  You can find the specifications for a Wells Gardner K7000 series at Happ.com
According to that, you need to  keep your horizontal sync between 15-25 KHz.  60KHz is too much  keep your Vsync between 47 - 63 Hz.  Powerstrip comes with plenty of documentation/help files, but there is a step by step write up here to make it easier.
http://forum.arcadecontrols.com/index.php?topic=43728.0
Ken Layton
  • Guru
  • Technician
« Reply #2 on: September 24, 2006, 12:09:12 am »
60 khz into a monitor designed only for 15 khz---what are you trying to do start a fire? ::)
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #3 on: September 24, 2006, 02:06:26 am »
Ken is absolutely right here..... Not only that but I hope you like a lot of very expensive monitor repairs!!
If you've got a 15Khz Monitor then feed it 15Khz......
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Panzer
« Reply #4 on: September 24, 2006, 02:15:28 am »
LOL, No i do not want to start a fire! When I spliced my Vga cord there was a ton of different color wires. Red, Red with White stripe, so on and so forth... I just wanted to see if I put the right wires together until I get a comp that can handle my video card... I guess patience is a virtue  :(
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #5 on: September 24, 2006, 11:51:33 am »
From K7000 Specs on happ's site:
# Horizontal Sync Frequency: 15.1 through 25.0 Khz
# Vertical Sync Frequency: 47 to 63 Hz
If you're talking H sync you'll fry it with that card if you don't know what you're doing! I didn't so I went with an ArcadeVGA. Don't try hooking wires up, make sure you know you're right before hooking it up :banghead:
RayB
  • I'm not wearing pants! HA!
  • Last login:July 03, 2025, 11:58:07 pm
  • There's my post
    • RayB.com
« Reply #6 on: September 24, 2006, 01:07:29 pm »
What did you expect, an out of focus image? It doesn't work that way.
NO MORE!!
