Author Topic: Translucent Happ Blue Trackball too bright?  (Read 1644 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: September 23, 2006, 12:46:26 am »
Am I the only one out there who can't stand the glow of that ball when the room is dark and I'm trying desperately to beat my children at Galaga?  :D
Has anyone tried to hook the 12v to the 5v molex? I'm looking more for a glow instead on a full-on beamer.
My old user name was marlborroman13, but I kicked the habit many years ago!
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
Re: Translucent Happ Blue Trackball too bright?
« Reply #1 on: September 23, 2006, 12:48:12 am »
Mine's lit by an LED and it's just right.
rdagger
« Reply #2 on: September 23, 2006, 01:51:24 am »
You could always use a potentiometer as a dimmer.
If you want to get technical there are circuits that will dim based on the brightness in the room.
ahofle
    • Arcade Ambience Project
« Reply #3 on: September 23, 2006, 02:01:33 am »
Yeah, I'm personally hoping that whammoed gets around to releasing these:
http://forum.arcadecontrols.com/index.php?topic=51658.0
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #4 on: September 23, 2006, 02:18:31 am »
Offsetting the LED will help.
AMDman13
« Reply #5 on: September 23, 2006, 02:32:43 am »
I am not using an led just the standard 12v lamp form Happ.
From what I've seen here... It looks like using an LED will actually make the trackball brighter which is what I don't want. I think I will try underpowering via the 5v and see how I like that. Personally I like the way the ball looks not lit. I think with using the 5v it would look not lit in daylight, but when dark it would give a very mild glow.
grantspain
« Reply #6 on: September 23, 2006, 03:50:13 am »
use a higher voltage bulb or like you say hook up the +5 to the bulb instead of the 12-if that bulb is really bright its possible happ put a +6v bulb in there(i've seen it done before) by accident
Level42
« Reply #7 on: September 23, 2006, 08:20:25 am »
If the 5 Volt is too dim, you can also feed it with 7 volts by connecting it between the 12V and 5V (12-5=7) volts.
