Author Topic: Hori problem  (Read 1835 times)
rumpelstiltzkin
Hori problem
« on: September 22, 2006, 07:46:34 am »
Hello i bought a hori arcade stick pro from play asia a while back but one of the buttons has never worked plus i could not send it back for fixing because the postage price was way to expensive also play asia would not cover the cost the ---daisies---. Luckily it has eight buttons so i can still play my beat-em ups but i still want to fix it somehow can anybody help is there any hori fixing websites or has anybody fixed one. Please help
somunny
  • Is it hot in here?
Re: Hori problem
« Reply #1 on: September 22, 2006, 12:56:31 pm »
Is this the PS2 Tekken stick, you're referring to?  If so...
http://himuragames.suddenlaunch3.com/index.cgi?board=techinfo&action=display&num=1109887687
SNAAKE
  • Trade Count: (+29)
Re: Hori problem
« Reply #2 on: September 22, 2006, 03:00:51 pm »
open it up and see if wires are loose or whatever. if the button actually "broke" or then you can change the button. get a sanwa button from ponyboy(buy/sell forum). hori sticks uses quick disconnect so you dont have to solder anything. maybe get all sanwa buttons while you are at it.
here is my modded hrap1..yes showing off ! >:D
« Last Edit: September 22, 2006, 03:02:47 pm by SNAAKE »
somunny
Re: Hori problem
« Reply #3 on: September 22, 2006, 03:38:01 pm »
That's mighty nice.
Zapatistab
  • Last login:July 05, 2007, 02:51:17 pm
Re: Hori problem
« Reply #4 on: September 22, 2006, 03:47:42 pm »
post a pic or link of stick.
rumpelstiltzkin
Re: Hori problem
« Reply #5 on: September 22, 2006, 05:56:10 pm »
Thanks for the info somunny funny enough i won a tekken hori stick of ebay before i even seen your reply so if i want to modify this would help loads. But the stick i was talking about is the real arcade stick pro the ones that snakke is showing in his pics only his is supremely modified and he must have removed the extra buttons. Your sticks are amazing snakke what are the little black and red buttons for and how did you make them killer backround pictures plus does the sanwa stuff make a more pro feel when using. :notworthy:
« Last Edit: September 22, 2006, 06:00:23 pm by expert level 7 »
SNAAKE
Re: Hori problem
« Reply #6 on: September 25, 2006, 12:12:02 am »
black and red buttons are start and select. pictures jacked from street fighter comic site and put together in photoshoped. printed on laser paper and hard laminated and of course sanwa buttons are better than hori :cheers:
