Author Topic: I'm proud of my neat solder job  (Read 3676 times)
crashwg
« on: September 21, 2006, 11:48:08 pm »
So I'll show it off!  8)
Yes the ruller is M$ painted in.  I forgot to put a ruler next to it when the xbox was open and I'm not about to open it just for another pic.  It is to scale though, I promise.
The chip that is seen is a Xerc2, which is used to control power and eject functions with an IR remote.  The set of three wires including the red one goes to the IR reciever mounted outside the case.
« Last Edit: September 21, 2006, 11:51:16 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
NightGod
Re: I'm proud of my neat solder job
« Reply #1 on: September 22, 2006, 12:10:14 am »
Nice work.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: September 22, 2006, 12:47:18 am »
Nice.  I'm exactly the same.  I've got pictures of my first Xbox mod with a penny sitting on the board for scale.  For us folks who only solder once every few years it feels like a big accomplishment.
Best Kid iPad Apps
« Reply #3 on: September 22, 2006, 07:25:54 am »
Those surface mount jobs with no way to mechanically attach the item are harder than through holed boards.
Chris
    • Chris's MAME Cabinet
« Reply #4 on: September 22, 2006, 08:14:10 am »
Great job!
My soldering skills have always been lousy, but I've always blamed my cheap Radio Shack pencil iron.  I recently bought a Hakko soldering station; haven't had a good chance to use it yet.  Hopefully it'll be better.
--Chris
« Reply #5 on: September 22, 2006, 09:26:59 am »
I had a hard time learning to solder at first... a crappy pencil iron and some questionable solder were contributors, but really, it was experience and comprehension of heat management that made me a good solderer.
People are not kidding when they say the best way to learn is to get a scrap board and practice on it.
Chris
« Reply #6 on: September 22, 2006, 09:30:11 am »
My boards always turn into scrap by ther time I'm done with them... does that count?  :)
--Chris
shmokes
    • Jake Moses
« Reply #7 on: September 22, 2006, 10:13:34 am »
Yeah, I'll second that.  The LPC on the Xbox was cake compared with the D0 and the 12 little solder pads on the the mod chip for hooking up an LCD screen.
Best Kid iPad Apps
« Reply #8 on: September 22, 2006, 10:18:20 am »
The d0 is still a through hole, from what I see in the pics, just a very small one.
One thing I would recommend from that pic above is taking the iron to those pads and reflowing that solder.  Maybe it's jpg artifacting but the blobs don't look all that smooth and odd shaped blobs go cold much easier.  Shouldn't take more than a couple of minutes.
If you're not comfortable doing that, though, and are just happy you did it without ---smurfing--- up the board, leave it as is and be happy.   :cheers:
Lewis Black
  • Last login:October 17, 2012, 08:14:10 am
  • Baaaah Eff it!
« Reply #9 on: September 22, 2006, 11:02:43 am »
Nice job, I'd be bragging about that too.
« Reply #10 on: September 22, 2006, 11:10:19 am »
Consider dropping some hot glue blobs on there to prevent those nonsecured wires from moving and shorting out in the future.
Stingray
« Reply #11 on: September 22, 2006, 11:17:43 am »
Wow, that's a tiny little chip. Nice work!
-S
« Reply #12 on: September 22, 2006, 11:19:07 am »
I bet it's 2 feet across and the ruler inset is enlarged.   :laugh2:
shmokes
    • Jake Moses
« Reply #13 on: September 22, 2006, 11:24:19 am »
I don't know.  Looking at my pictures I see a bunch of through holes, but the D0 looks like a solderpad.  At any rate, through hole or not, it was so bloody small that it was much more difficult than the 12 wires I had to solder to the chip for the LCD screen.
Best Kid iPad Apps
« Reply #14 on: September 22, 2006, 11:28:56 am »
It is pretty freakin small.  If you flip the board over, though, what you'll probably see is that the point of the d0 is to connect the end of a trace on the top to the beginning of a trace on the bottom.  The hole is probably too small to actually insert the wire into which does make it the same as a surface pad from your point of view.
shmokes
    • Jake Moses
« Reply #15 on: September 22, 2006, 12:02:27 pm »
I'm sure you're right, cos you can solder the D0 on either side of the board.  The funny thing is that the one in the picture is the "big" d0 point on the underside of the board.  A lot of people don't bother taking out the motherboard and just solder to the more difficult d0 up top.
Best Kid iPad Apps
« Reply #16 on: September 22, 2006, 12:08:55 pm »
Best way to do one that small is to pretin the wire.  That way you don't have to apply solder to the tiny pad.  Just touch the wire to it and heat it up.
shmokes
    • Jake Moses
« Reply #17 on: September 22, 2006, 12:15:25 pm »
By the way, what's wrong with a radioshack pencil soldering iron?  That's all I've used.  Would my soldering life be that much improved with a $60 setup?
Best Kid iPad Apps
« Reply #18 on: September 22, 2006, 12:41:01 pm »
If you soldered a lot, absolutely.  Different situations call for different temperatures and your pencil iron has no temperature control whatsoever.  It just gets as hot as its power supply can make it while still losing heat to the air.
Consistent temp control adds a lot to soldering ability when faced with jobs of varying requirements.
crashwg
« Reply #19 on: September 22, 2006, 12:58:02 pm »
I soldered to the top D0 point...  I'm not about to post pics though because it doesn't look good.  In my defense, it was the second thing I soldered with the first being a PS1 chip which is easy and then there's the fact that it actually works!  :D
Oh, and I'm pretty darn sure that the D0 point is NOT a through hole.  The wire used to connect it is 30g and if that doesn't go through nothing will.  Also I put a light behind the mobo and couldn't see through it.
Lemme say it again
« Reply #20 on: September 22, 2006, 01:09:08 pm »
Note that the term "through hole" refers to the PCB itself, not the tin contact point.  It could easily be a through hole without actually having a hole through which you could poke a wire.
shmokes
    • Jake Moses
« Reply #21 on: September 22, 2006, 01:45:21 pm »
I don't see how it could possibly look too bad.  It's surrounded by other traces.  There's only enough froom for the smallest dot of solder there.  The underside was difficult enough, so good job on successfully doing the top (though, with no soldering experience I don't know what the ---fudgesicle--- you were thinking  ;D  )
Best Kid iPad Apps
« Reply #22 on: September 22, 2006, 01:47:39 pm »
It would look bad if he fried the laminate around the hole itself... that gets ugly, especially if he left the flux there.  The flux always makes burn damage look worse.
Stingray
« Reply #23 on: September 22, 2006, 03:57:21 pm »
That's what I use too. I've got a 15 watt & a 30 watt. Of course I only do the occasional repair for myself, it's not like I use them every day.
-S
« Reply #24 on: September 22, 2006, 04:27:49 pm »
I have one but really don't like it.  Can't get decent tips for it and the tip burns way too easily.
I picked up one of these when the local RadioShack went buhbye.  It was like $3.50.  It's not too bad but it's not the one handed solution they would have you believe.  Especially when your finger slips off the bulb and it sprays wet solder onto the board.
I also have an MCM 21-6050 20/40 watt station.  It's okay.  Does the job.  Don't like the way the tips are held in.
The tool I use most is an OLD Weller station I got off Freecycle.  No temp control but it seems to have the best regulation of any unregulated iron I've used.  Gets hot fast, stays hot, doesn't burn itself.  Put a quality tip in it and it's gold.  Probably 30 years old but damn good.  Can't beat pure quality.
Stingray
« Reply #25 on: September 22, 2006, 04:43:04 pm »
That's funny. I bought the same item just yesterday. It may not be a perfect solution, but it's a lot better than a regular soldering iron and a solder sucker.
-S
« Reply #26 on: September 22, 2006, 09:40:16 pm »
Eh, I went back to the iron and the sucker pretty quickly.  Once you get good with that sucker you can often make parts just fall out of the board on the first try.
shmokes
    • Jake Moses
« Reply #27 on: September 23, 2006, 11:31:29 am »
All I've used is the copper braid.
Best Kid iPad Apps
« Reply #28 on: September 23, 2006, 11:55:09 am »
I use that too in some situations.  It forces you to heat up too large an area, though, on most spots.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #29 on: September 24, 2006, 07:40:04 pm »
Pure mangle gold right there! ;D
Stingray
« Reply #30 on: September 25, 2006, 03:21:55 pm »
I can't make that stuff work to save my life. I'm a big fan of the desoldering iron after having used one for a bit. I'm not sure how I ever lived without it. ;)
-S
« Reply #31 on: September 25, 2006, 03:25:41 pm »
I like braid when the solder is contaminated.  Contaminated solder doesn't completely liquify.  It just becomes a weird sludge that braid will mostly pick up but a hand sucker or pump won't.  Contaminants would be stuff like burned solder or acid damaged solder (or both).
shmokes
    • Jake Moses
« Reply #32 on: September 25, 2006, 09:14:03 pm »
The first time I used copper braid I tried and tried and I was burning the hell out of the board, but the braid wasn't picking up anything at all.  I was like, "What the hell, this stuff doesn't work.  Period.  I can't possibly be doing it wrong, you just put the braid over the solder and apply the soldering iron."
Since then it's always worked extremely well for me and as far as I can tell I'm not doing anything differently.  I don't know what was up the first time, but it sounds like whatever it is it might be the same problem you're having.
Best Kid iPad Apps
« Reply #33 on: September 26, 2006, 08:43:53 am »
If it's burning the board you are using it wrong.  It shouldn't be touching the laminate.
shmokes
    • Jake Moses
« Reply #34 on: September 26, 2006, 10:33:48 am »
It wasn't.  I was just holding it against the braid, which was in turn sitting on the solder, for so long trying to get the braid to suck something up, that the proximity to the board, and perhaps heat transfer, was burning the board.
I don't know.  Obviously I was doing something wrong, but I'll be damned if I can figure it out.
Best Kid iPad Apps
