Author Topic: What test can I run to see whether my monitor works?  (Read 841 times)
Panzer
  • Last login:December 05, 2008, 08:04:25 pm
« on: September 18, 2006, 05:05:53 pm »
I have a MK2 cabinet with an NFL BLitz conversion. The Cab powers up but there is no sound nor picture. When I turn it on the screen flashes a bit, and when I shut it down the picture does one of those small flash outs l ike the old television used to do.
Is there anything I can do to test whether I need a new monitor and or speakers?
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
Re: What test can I run to see whether my monitor works?
« Reply #1 on: September 19, 2006, 09:44:48 am »
You might get a better response in the montior forum.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: September 19, 2006, 10:44:45 am »
The fact that you mentioned there was no sound makes me believe that the actual game may not be coming on at all. The marquee will because it's just a light fixture like any other light in your house, the monitor effect you're seeing leads me to believe the monitor is "functioning" but without a video signal. Check out the power supply and the game pcb for loose connections etc. You should be able to at least play the game "blind" (no video on the monitor) if the game itself were working correctly. Don't count out the monitor until you can actually hear a game being played.
Is the regular NFL Blitz a hardrive game? (I think 99 and up is, but not sure on the older one) If it does have one, is the hardrive spinning up and functioning at all?
