Author Topic: HELP WITH ROTATING MONITOR 90 DEGREES  (Read 1874 times)
langdoguk
  • Last login:October 30, 2009, 03:45:23 pm
  • hey you Guys !
« on: September 18, 2006, 02:09:40 pm »
Hi can someone please tell me an easy way to rotate my picture 90 degrees so I can turn my monitor on it's side? I can do it with this pc but when I go into display on my cabinet monitor it doesn't offer to rotate it , I'm using xp on both , I'm not very good with pc's , so is there any easy way to do this , THANKS
Help I'm useless !!!!
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: HELP WITH ROTATING MONITOR 90 DEGREES
« Reply #1 on: September 18, 2006, 03:47:16 pm »
Are you trying to run windows vertically or are you trying to just run the "front-end" vertically to pick vertical games.
If you are trying to run vertical games all you must do is allow windows to start however it wants to but have a "vertical friendly front-end" in your startup folder.
When the front-end loads it will be vertical.
I would suggest MALA as your front end since it is very user friendly.
I hope this is more helpful than confusing.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
langdoguk
  • hey you Guys !
« Reply #2 on: September 18, 2006, 05:00:42 pm »
I'm trying to run windows verticaly , I've struggled trying to use front ends , any I got working missed out games etc, so I just use mame 32 and wanted to turn it 90 degrees , thanks.
Lutus
« Reply #3 on: September 19, 2006, 10:58:12 am »
Have you tried Mala?
Once it is running, you right mouse click, highlight orientation (i believe) and click "rotate".
Thats it, done.
Give it a shot, it will be much easier to rotate the frontend rather than trying to rotate windows and everything.
max8061
  • Last login:April 18, 2007, 10:31:02 am
  • Aroo!
« Reply #4 on: September 19, 2006, 06:31:33 pm »
If I understand your original post correctly, you are saying that there is a rotate feature on your XP PC, but a second XP PC that is in your cab does not show this feature?
If so, the rotate feature is a function of the video card drivers - not XP. It might help if you tell us what video card/drivers you are using.
