Author Topic: Faint vert line 3/4 up the screen help!!  (Read 1959 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: September 07, 2006, 01:08:14 am »
Ok so i have a wg7000 monitor in a mk2 cab which was converted to play mace, now when i play mace at the top right hand Corner I see some v-synch lines which are out of place with fair amount of adjusting its barley noticeable, however when I plug my pc (arcadevga) in I get a faint v-synch line across
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Ken Layton
  • Guru
  • Technician
Re: Faint vert line 3/4 up the screen help!!
« Reply #1 on: September 07, 2006, 01:21:22 am »
19" or 25" tube?
MAME TIME
« Reply #2 on: September 07, 2006, 01:53:34 am »
25" bud, i guess i would say its more like a bar across and not a line, thx
Geometry Arcade
Neo Geo 360
MK2 standup
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 07, 2006, 01:59:00 am »
Check out this site:
www.jstookey.com/arcade/WG_25k7191/
Have you adjusted the 50/60 pot? It interacts with the vertical size and vertical hold too.
Has this monitor had a capkit recently?
MAME TIME
« Reply #4 on: September 07, 2006, 09:12:05 am »
hey ken i just picked up this monitor at a auction, so im not able to tell you if a cap kit was done, how can i tell?? when you say the 50/60 pot, im assuming theres another knob on the board, i had a look and dont recall seeing another pot knob, when i get home i'll have another look, one more thing ken on http://www.jstookey.com/arcade/WG_25k7191/wg-k7000.pdf
page 9 photograph 4 is excatly whats happening
« Last Edit: September 07, 2006, 09:26:10 am by MAME TIME »
Geometry Arcade
Neo Geo 360
MK2 standup
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #5 on: September 07, 2006, 09:23:20 am »
Usually, if the cab has a fair amount of dust in it, the new capacitor will be much brighter when compared to rest of the chassis.  As in, will look newer.
Also, download a "cap kit" map for that particular chassis and check to see if the replacement capacitors match the capacitance and voltage values of the "cap kit".  Also, all the replaced capacitors should be uniform.  (They should look like they came from the same factory with the same looking casing.  Usually Xicon bright blue.
I think thats what you mean anyways.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
grantspain
« Reply #6 on: September 07, 2006, 09:23:32 am »
its not something as silly as the screen volts a touch too high,that will give you a faint flyback line even tough your picture will be good
MAME TIME
« Reply #7 on: September 07, 2006, 09:30:28 am »
would there be a way i can adjust the screen voltage? im taking alook at these diaghrams
Geometry Arcade
Neo Geo 360
MK2 standup
grantspain
« Reply #8 on: September 07, 2006, 09:42:47 am »
on the f l y b a c k transformer there are two adjustments-focus and screen volts,just turn your screen volts antclockwise a touch.you may have to turn up your contrast/brightness or colour gain pots to compensate for the loss in picture quality
« Last Edit: September 07, 2006, 09:45:44 am by grantspain »
MAME TIME
« Reply #9 on: September 07, 2006, 10:43:48 pm »
intresting turn of events, games like mslug, garou, play with that bar, however when i load up mk1 2 or 3 that bar doesn't show up. possible ini issue with those games??
Geometry Arcade
Neo Geo 360
MK2 standup
SirPeale
  • Green Mountain Man
« Reply #10 on: September 08, 2006, 07:20:08 am »
A lot of games share the RAM with other parts of the system, and the results show up on screen.
The older Williams games are a good example of this.  On the very top of the screen there is a single row of pixels that changes a lot.
The Mame guys wrote around this so it wouldn't show up on screen to stem the flow of 'is this a bug' reports.  But it's viewable on an actual machine.
MAME TIME
« Reply #11 on: September 08, 2006, 10:34:06 am »
guys thanks for all your suggestions, i did a re-install of mame and windows, adjusted the 50/60 pot in the rear and everything is ok, once again thanks
Geometry Arcade
Neo Geo 360
MK2 standup
