Author Topic: opti pac worked, now after greasing t.ball it doesn't.  (Read 881 times)
katuuuz
  • Last login:December 12, 2016, 09:39:44 pm
  • U, U, D, D, L, R, L, R, B, A, Select, Start
« on: September 06, 2006, 04:31:15 pm »
the problem at first was i didn't have the jumper plug on the usb prongs.  now i got that figured out, and it was working fine, just had to grease the ball.  so i opened up the ball greased it up, and upon plugging everything back in, it was "usb unrecognized" all over again.
RandyT
  • Last login:Today at 09:37:19 am
    • GroovyGameGear.com
Re: opti pac worked, now after greasing t.ball it doesn't.
« Reply #1 on: September 06, 2006, 08:34:05 pm »
Did you plug it into the same USB port?  Don't ask me why, but Windows seems to want to load new drivers when you plug USB devices into different ports.
RandyT
katuuuz
« Reply #2 on: September 06, 2006, 08:37:44 pm »
yes.  i'm really trying not to format for i just have, and it took like 2 hours a back-up dvd to dump onto the fresh hardrive.  basically we're talking d/l 68 gigs of games off of burned dvds if this is the case.  took like 3 days last time.  plus if it's not guaranteed to work afterwards, it's a total waste of my time.
