Author Topic: Illuminating control panel  (Read 2766 times)
anoon
  • Last login:November 03, 2022, 09:24:53 pm
« on: March 18, 2003, 02:32:52 pm »
Hey there,
I have transucent leaf switch buttons and want to light them up from underneath.  Has anyone tried putting a flourescent lamp inside their control panel box and wiring to the power supply of the cabinet? Would that work?
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Illuminating control panel
« Reply #1 on: March 18, 2003, 03:34:36 pm »
i think you have to use sright LED's.. there are several discussions about this. Try search, or the FAQ at the top of this forum...
  • Last login:July 30, 2025, 06:08:43 pm
« Reply #2 on: March 18, 2003, 03:39:19 pm »
The lamp will also work but it's not as good as the light it puts out is rather directional.  Of course bright leds are the same way, but they are much brighter and are smaller so you can put one under each button.
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #3 on: March 18, 2003, 03:43:47 pm »
I thought the bright LEDs are geared towards the Happ non-translucent push buttons.  It seemed like the consensus was that an super LED will light up a translucent button like a MOAB.
This opinion was created from 100% post consumed information.
dhansen
  • Last login:July 09, 2025, 05:07:33 pm
  • No Quarters Needed
    • Arcade Stupidity
« Reply #4 on: March 18, 2003, 03:46:03 pm »
This guy used the flourescent light, he seems to like it...
http://home.neo.rr.com/martinko/mame.htm
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #5 on: March 19, 2003, 01:02:35 am »
You can easily reduce the brightness of LEDs using resistors, or just buy less bright LEDs.
My other job...
Wienerdog
« Reply #6 on: March 19, 2003, 02:03:12 am »
True, but then I couldn't use MOAB in a sentance...
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #7 on: March 19, 2003, 10:27:41 am »
Moab?
http://www.moab-utah.com/index.html
If you build a frankenpanel, chances are I don't care for you as a person.
Bursar
  • Last login:September 14, 2005, 06:57:07 am
« Reply #8 on: March 19, 2003, 11:22:47 am »
You can also lightly sand the LED to help diffuse the light. Nothing major, just rough up the casing a little bit.
anoon
« Reply #9 on: March 19, 2003, 11:00:40 pm »
Cool, thanks for the link Dhansen. I already happened upon a flourescent lamp that fits PERFECTLY in my CP box, I was afraid of interference from the lamp. If that guy was doing it, I'll give it a shot as well. Worst comes to worst, I'll pull it out.
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #10 on: March 19, 2003, 11:11:58 pm »
Moab?
I'm thinking "mother of all buttons"..:-)
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
Wienerdog
« Reply #11 on: March 19, 2003, 11:37:02 pm »
Mother of all Bombs, Mother of all Buttons, you got it.
Brax
« Reply #12 on: March 20, 2003, 12:41:52 pm »
http://www.arcadecontrols.org/arcade.htm
Here's a nice example. IMO one flourecent does the job fine and you don't have to wire up 25 LED's.
