Author Topic: Help with a Blitz to Blitz '99 upgrade needed  (Read 3422 times)
johnnya
  • Trade Count: (+26)
  • Last login:January 08, 2023, 10:37:08 pm
  • Who's gonna turn down a Junior Mint?
« on: September 05, 2006, 02:12:13 am »
I just installed a new hard drive and an all new board to my Blitz, in order to make it a Blitz '99.  First, the hard drive wouldn't work.  It was making the click of doom.  I got an old hard drive I had sitting around and put the chd image onto it.  Problem solved.  But some of the graphics are funky.  The character models and field and whatnot are fine, but the letters are screwy.  Could it be bad main board roms?  Each time I boot, the graphics get a little different, and one time they were perfectly fine.
johnnya
Re: Help with a Blitz to Blitz '99 upgrade needed
« Reply #1 on: September 06, 2006, 08:20:25 pm »
 :banghead:
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: September 06, 2006, 08:49:25 pm »
do you have blitz 99 roms installed? how about a blitz 99 security chip?
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 06, 2006, 09:27:09 pm »
Try re-seating all the socketed chips.
Sounds intermittent to me.
johnnya
« Reply #4 on: September 06, 2006, 09:45:42 pm »
The auction I got it from said it was pulled from a "working machine" but of course was a "no return" auction.  They should be blitz 99 roms though.  The one says blitz 99 on it.  The other 2, the labels have fallen off.  I pulled all 3 socketed roms, cleaned the contacts, and reinserted them, to no avail.  This does look like a rom problem though, correct?
MonMotha
« Reply #5 on: September 06, 2006, 10:39:14 pm »
When my Blitz 99 was doing that, it was actually a hard drive problem.  The drives Midway used normally (Quantum Fireballs) are REALLY touchy about their power rails and will spin up/down constantly every time there's a little blip.  I fixed that (before rewiring my JAMMA harness with more larger power wires - previously each pair in the power section had only 1 18ga wire) by powering the HDD separately, which was easy since I use a PC PSU in the first place.  That stopped the constant spin retries and also fixed my graphics.  The game appears to not wait very long for graphics to load and seems to just fail in a mode of displaying untextured blocks if it can't load things up in time.
Also check your IDE cable.  It seems very picky about length.  The cable that came with my setup wasn't quite long enough to properly mount the HDD (NOS kit ---my bottom---), so I substituted from my box o' computer cables, but I had to finally find a short one (or you can make one) to get it working reliably.  In this case, though, the symptom was that it wouldn't cut over to the HDD loader (where it identifies the game as Blitz 99 and then gives the title screen) from the ROM loader (where it does the self-tests).
If your self-test function is disabled (it's one of the DIP switches in group 2), re-enable that.  I have a manual for original Blitz if you don't have a manual.  It may find something wrong.  There should also be a drive check in test mode that you may want to run.
In other words, check your HDD again and make sure it's not still spinning up/down and that your image is good.  If all else fails, I can dump the ROMs (I already imaged the HDD) from my setup and you can try that since mine does work.  If there's a separate security device, I'd have no trouble sending you those images (especially since MAME can't actually emulate Seattle in realtime).
johnnya
« Reply #6 on: September 06, 2006, 11:28:33 pm »
The hard drive seems to be working fine.  The self-test was enabled, but once it ran, it just reset itself and would run again.
At first, the hard drive came up bad, but like I said, I threw a new hard drive in and the test ran fine.
I have a regular blitz manual too, and I couldn't find any help in there.  If anyone has a blitz 99 manual, that may be of some help, but I don't really know.
I would like to try replacement roms, but I don't have a way of replacing the roms, other than buying new ones, but I haven't found a source for those either.
I also have a completely working blitz board.  Could I just swap the three roms and try that?  The reason I ask is because I don't know, and can't find, the information on what the upgrade consisted of.  Was it just the roms?
Also, my old board was 2 player and the new one is 4 player, but from what I understand, that is managed by the roms.  Do you have information on how to wire the board for 4 player?  There is a separate board on the control panel for the 4 player one, but I haven't no idea how to wire the thing.
Lot of questions with this stupid upgrade, but I knew it wouldn't be easy.
SirPeale
  • Green Mountain Man
« Reply #7 on: September 07, 2006, 05:18:05 am »
Silly question but...have you checked your voltage?
johnnya
« Reply #8 on: September 07, 2006, 12:43:06 pm »
I don't remember if I had or not.  I know my Blitz board an drive worked flawlessly though, but now the 99 ones won't work correctly.  I'll check that.
johnnya
« Reply #9 on: September 13, 2006, 01:27:55 pm »
I had new eprom images burned, and that has solved the problem.  I still need info on how to wire the control panel though.  If anyone has either a manual or the actual cab, please let me know.
Q*Bert_OP
  • Oh yes, we did!
« Reply #10 on: September 13, 2006, 06:18:25 pm »
I do...what do you need?
johnnya
« Reply #11 on: September 14, 2006, 01:10:22 am »
I previously had a 2 player CP, but I got a new 4 player one, and I don't know how to wire the pcb inside the control panel, as the 2 player one didn't have this.  I assume it takes the 4 player's joysticks and combines the signals somehow into the 2 hookups on the main pcb.  Any help would be great.
Q*Bert_OP
  • Oh yes, we did!
« Reply #12 on: September 14, 2006, 06:39:40 pm »
You need midway's 2-t0-4 input I/O pcb...this was supplied with those '99 kits and in the dedicated cabinet..
johnnya
« Reply #13 on: September 14, 2006, 10:01:25 pm »
Yes, that's the board I was referring to.  I need to know how to wire it, i.e. pinouts.
