Author Topic: G07 has no neck glow  (Read 7341 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: August 31, 2006, 11:13:57 pm »
The 19" G07 in my Centipede cabaret seems to make those sounds like it's getting power, but I get no neck glow (and of course, no picture). I can hear the game playing blind and the self-test reports no beeps.
Fuses on the monitor are good.
I've been told to measure power related to the "B+" which I'll do tomorrow (when I have some daylight and can see!)
Any other tips on where a fault might lie?
NO MORE!!
Ken Layton
  • Guru
  • Technician
Re: G07 has no neck glow
« Reply #1 on: September 01, 2006, 12:01:15 am »
Likely needs a capkit.
SirPeale
  • Green Mountain Man
« Reply #2 on: September 01, 2006, 07:50:10 pm »
Touch up the solder joints around the flyback.
RayB
  • There's my post
    • RayB.com
« Reply #3 on: December 06, 2006, 12:58:28 pm »
Just wanted to post the resolution to this, in case anyone finds this thread by search: a Cap Kit fixed the problem.
« Last Edit: December 07, 2006, 01:09:44 am by RayB »
NO MORE!!
Solvalou
  • Last login:September 06, 2007, 01:25:08 pm
« Reply #4 on: December 08, 2006, 10:09:18 am »
Hi I'm new here, and I got exactly the same problem,
but the Monitor was working until I've shorten the big white resistor on the left.
My first problem was that I've got a jittery picture:
http://youtube.com/results?search_query=monitor+flackert&search=Search
this problem is still existing, but now the monitor isn't working
I also installed a Cap Kit, but it doesn't help
Any ideas?
First I will check the resistor
Sorry for the bad english, because I' am from Germany ;)
grantspain
« Reply #5 on: December 08, 2006, 10:19:27 am »
solvalou,your original fault is the sync or adjustments
you have probably broken a track of the circuit board during the resistor change that is causing your present problem
Solvalou
« Reply #6 on: December 08, 2006, 10:36:32 am »
ok, thanks
What can I do?
The resistor shows in one Moment a value of about 180 Ohm and then nothing!
grantspain
« Reply #7 on: December 08, 2006, 11:03:38 am »
is it possible to put the old resistor back in?
where are you reading the resistor,on the legs or the track?
Solvalou
« Reply #8 on: December 08, 2006, 11:09:45 am »
thanks for your help first
Its such a resistor:
I measured at the legs
I don't tried it without yet, but with it, I've got high voltage, but now neck glow
grantspain
« Reply #9 on: December 08, 2006, 11:22:33 am »
its very possible you have damaged the circuit board track whilst changing the resistor,you need to check this first -look for tiny cracks or lifted track
perhaps it may be better if you make this a new thread
Solvalou
« Reply #10 on: December 08, 2006, 11:31:37 am »
I didn't changed it!
I wanted to measure the voltage of the resistor and then I've maked a short circuit!
But at the end its the same, isn't it?
grantspain
« Reply #11 on: December 08, 2006, 11:53:22 am »
sorry i am not too sure what you are saying,i understand that you did not change the resistor its the bit about reading voltage and making a short i don't understand
Solvalou
« Reply #12 on: December 08, 2006, 11:56:59 am »
no problem, my english isn't very good
grantspain
« Reply #13 on: December 08, 2006, 12:00:43 pm »
have you checked all the fuses?
Solvalou
« Reply #14 on: December 08, 2006, 12:03:53 pm »
Yes I did, on was broken, but I changed it
grantspain
« Reply #15 on: December 08, 2006, 12:25:13 pm »
let me get this correct,
the original fault is the sync issue(the picture not locking)
then you did what exactly that caused a fuse to blow?
Solvalou
« Reply #16 on: December 08, 2006, 04:51:49 pm »
I've shorten the white resistor! Then the fuse was blowing up then I put a new one in and the neck glow was missing
grantspain
« Reply #17 on: December 08, 2006, 05:00:39 pm »
why did you shorten the resistor?
Solvalou
« Reply #18 on: December 08, 2006, 05:03:09 pm »
It was a mistake!
grantspain
« Reply #19 on: December 08, 2006, 05:24:29 pm »
well the only way you could have caused damage to the chaasis is if you have broken the track around the resistor(also check for solder splash) or you have blown a safety resistor to tube heater voltage-get yourself a schematic of the chassis and follow the circuit of the resistor because it will take you to the faulty component
Solvalou
« Reply #20 on: December 08, 2006, 05:31:42 pm »
thanks for your help  ;) ?
I will test the parts in the circuit tommorow!
Solvalou
« Reply #21 on: December 09, 2006, 12:31:32 pm »
short question,
when I am measuring the resistor, the multimeter is showing about 200 Ohm only for a second and in the next moment nothing!
Is this normal?
grantspain
« Reply #22 on: December 09, 2006, 01:40:13 pm »
either the resistor is broken or the track is broken/or you have set your meter on the wrong setting
what value is written on the resistor?
Kevin Mullins
    • Me on Myspace
« Reply #23 on: December 09, 2006, 01:50:20 pm »
I believe what he is trying to say is he accidentally "shorted" the resistor while trying to measure the voltage while power was on. Which probably took out the voltage regulator transistor or something. From the looks of the size of that resistor it is definetaly part of the power supply section. (which is why the monitor is completely dead now)
As for measuring the resistor and having it blink about 180-200 Ohm and then nothing, make sure your multimeter is on the proper setting to read the rating of that resistor. The rating should be marked right on the resistor itself. Also make sure you are reading from a good clean spot on the legs.
Also look for any burn or crack marks on the resistor.
Solvalou
« Reply #24 on: December 09, 2006, 02:04:41 pm »
Oh yes, sorry
I've got a wrong option at the multimeter.
I've tested the shorten resistor and the two excistig fused resistors, but they are all okay!
« Last Edit: December 09, 2006, 02:16:14 pm by Solvalou »
grantspain
« Reply #25 on: December 09, 2006, 03:38:16 pm »
i think kevin is correct,you may have done some serious damage to the monitor its probably best for you to get a tv tech to look at the monitor
Solvalou
« Reply #26 on: December 09, 2006, 03:42:03 pm »
---steaming pile of meadow muffin---, thats bad!
But first I will test the power regulater transistor, thanks for help!
Solvalou
« Reply #27 on: December 09, 2006, 04:37:50 pm »
I put the transistor away, there was some white fluently stuff under it, does anyone know what this is?
grantspain
« Reply #28 on: December 09, 2006, 05:37:15 pm »
heatsink compound also known as heat conductive grease,that should be there
Solvalou
« Reply #29 on: December 10, 2006, 05:39:32 am »
ok, I remembered that, sorry :P
Solvalou
« Reply #30 on: December 10, 2006, 09:21:29 am »
Ok, I was measuring with the diode test about 400 between the base and the collector and about 330 between base and emitter and 90 between emitter and collector
I think the transistor is death, isn't he?
Solvalou
« Reply #31 on: December 14, 2006, 11:51:27 am »
Its a 2SC1106 Transistor from NEC, does anyone know, where to get the specs for this transistor?
