Author Topic: Mala And background Music  (Read 6696 times)
CyrusMzRG
  • Last login:July 14, 2019, 07:01:50 pm
« on: August 30, 2006, 06:31:51 pm »
hi people... may be it is a simple question, but I cannot find a solution for it.
Tha fact is that I have a directory where the music for mala is located. But when I start MALA ALWAYS starts with the same track... are there any solution which MALA select aa random track when I start it?
Thank you
Cyrus
loadman
  • Moderator
    • MaLa
Re: Mala And background Music
« Reply #1 on: August 30, 2006, 07:04:58 pm »
Thank you
Cyrus
Its a bug in current versions.  It worked fine on earlier versions.
Another Job for SWINDUS   :(
You can allocate a button on your cab to skip to the next track. If its in random mode you will get a diffrent song. Works for me
« Last Edit: August 30, 2006, 08:36:56 pm by loadman »
CyrusMzRG
« Reply #2 on: August 30, 2006, 09:55:32 pm »
Hi Loadman, yes I have asociated a button for passing the next track, but as I said I would like mala do it automatically...
I hope Swindus can fix it for next version
Thank you for your help
Cyrus
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
« Reply #3 on: August 31, 2006, 07:02:25 am »
I'm not using Mala yet, but if it's starting on the same track (presumably the first in the folder?) each time, you might be able to work around this by putting a short (say, 2-5 second) "blank" track at the top of the folder.  Perhaps that would play, then go on to random tracks?
If the random track selection is broken entirely, and not just for the first track, feel free to disregard my rambling.  :P
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
CyrusMzRG
« Reply #4 on: August 31, 2006, 07:55:37 am »
good idea... I'm going to check if the first song that is played is the first one into the directory
loadman
  • Moderator
    • MaLa
« Reply #5 on: August 31, 2006, 07:58:54 am »
That is thinking 'Outside the box'   ;)
I can't test that idea right now but I am sure to try it later   :cheers:
Try first in playlist too!
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #6 on: August 31, 2006, 10:05:41 am »
I can confirm that it's always the first song in the playlist. Also, the random feature has a tendency to grab the same songs over and over again - but at least it's picking different songs.
Make your cabinet look its best with custom art from
Gamecreature!
Chris
    • Chris's MAME Cabinet
« Reply #7 on: August 31, 2006, 10:26:18 am »
I wonder if that's intentional.  DOSCab/WinCab's random feature shows a preference for songs you play most often; maybe something similar is going on here.
--Chris
loadman
  • Moderator
    • MaLa
« Reply #8 on: August 31, 2006, 06:57:34 pm »
last time I asked about this SWINDUS indicated it may be due to something 'buggy' in BASS.DLL
fatfingers
  • Got UltraStiks?™
« Reply #9 on: August 31, 2006, 07:46:16 pm »
If Swindus is using a standard random number generator to pick the next song to play, he must be sure to seed the random number generator with a different value each time Mala starts (usually using temporary data on the system like load levels, processes running, some combination of both, etc.).  Random number generators are only as good as their seed.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
gamecreature
    • Gamecreature
« Reply #10 on: September 01, 2006, 10:05:03 am »
A quick fix to this is to just check the last box on the background music screen to get MaLa to start with the last song that was playing when you shut it down.
Gamecreature!
