Author Topic: Help With Monitor?  (Read 5013 times)
Itatemyquarter
  • Last login:September 25, 2006, 09:33:53 am
Help With Monitor?
« on: August 26, 2006, 08:09:47 pm »
I picked up the game, gunsmoke near me which i won on ebay and the problem was something wrong with power supply. Its' a centipede cabinet with all the wires and stuff and you can see the centipede burn on the monitor. I got it home and turned it on , but all i see on the monitor is an vertical orange bar of some sort, (see picture ). You can hear some of the game sounds somewhat.  Anyway, before i go further, anyone have any idea ? I have to take the back top board off the cabinet to really get into the see what the make and model the monitor is, as i can't see it now.
I searched all over the internet, with nothing, maybe i am looking in the wrong places..Hope someone can help.
Thanks :dizzy:
SirPeale
  • Green Mountain Man
Re: Help With Monitor?
« Reply #1 on: August 27, 2006, 07:29:25 am »
Vertical collapse.  Could be caps, could be cracked joints.
You don't have to take the top off the cab, just remove the back door.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 27, 2006, 01:29:36 pm »
And the make & model number of the monitor in question is....????
Kevin Mullins
    • Me on Myspace
« Reply #3 on: August 27, 2006, 02:04:37 pm »
Let me guess.... WG K4600 series?  ???
I'd go for the cap kit and solder joints theory with Peale.
Itatemyquarter
« Reply #4 on: August 27, 2006, 05:16:27 pm »
I will have to take the monitor out to see the make and model # as they arent not visible right now. I will post later this week when i can get the monitor out.
i just did not know what the bar on the screen was.
P.S.
This will be my first time taking out the monitor. i've read so much on taking it out, so i pray to god i can do it safe.
SirPeale
« Reply #5 on: August 27, 2006, 05:19:56 pm »
Centipede...might have a G07.
Itatemyquarter
« Reply #6 on: August 27, 2006, 05:40:18 pm »
You think its better getting a new monitor or just fix it. I also need a 19" monitor for my power drift stand up. Any standard res. will work?
Ken Layton
  • Guru
  • Technician
« Reply #7 on: August 27, 2006, 06:15:13 pm »
Remember that regardless of what the cabinet is, someone could have changed out the monitor that was originally in it. In other words there could be just about any monitor in there. That's why it's important to get the make and model.
SirPeale
« Reply #8 on: August 27, 2006, 10:16:52 pm »
Some monitors are easier to fix than others.  You should at least *try* to fix it.
Itatemyquarter
« Reply #9 on: August 29, 2006, 08:49:43 pm »
Haven't got to the the monitor in my centipede cabinet (which is supposed to run gunsmoke) yet, but i haven't tried the vertical horizontal buttons yet, as i looked at my other monitor which the colors were bad , but i fixed them and fooled around with the vertical and squished the pic like what the other monitor looked like. confused? :P
Now in the pic you'll see that the fuses on the power block thing has 2 wires cut and has been taped together. if you can see what i mean , is it normal? because i have the same thing in my other cab but the wires are connected to fuse.
damn hobby :)
« Last Edit: August 29, 2006, 08:51:27 pm by Itatemyquarter »
Itatemyquarter
« Reply #10 on: August 30, 2006, 06:42:37 pm »
Sorry for being the annoying guy. heres a little more info. i messed with the monitor with no luck.
heres what i found on the monitor . GO7-CBO 1981 SERIAL 14134
38-GO7904
hope this helps.
anyone anyone
thanks
SirPeale
« Reply #11 on: August 30, 2006, 09:12:17 pm »
You have an Electrohome G07.
The wires were probably taped together because the fuse kept blowing.  Not a wise thing to do.  Is that the fuse that handles the monitor?
Itatemyquarter
« Reply #12 on: August 31, 2006, 04:52:02 am »
I will check into it. the fuse is blown , yes. Ill see if i can some fuses, if there not hard to find and reconnect the wires, and let ya no what happened. after all, there are wires that have been snipped in a few places (which i took care of some). it seems like a bad trace somewhere around that area and the game board because i cant hear the game running, just some sounds if i keep powering the game on and off, like it is trying to come on. still a squished vertical bar. maybe something to do with a video connection?
I wanted a challenge and got one. Not as easy as it looks.   :-\
Itatemyquarter
« Reply #13 on: September 09, 2006, 09:10:01 pm »
20 amp fuse (has the wires taped together), is that for the monitor?
I also took the pcb game out and turn the monitor on with same results and change the big blue cap and still the same. the game is at my inlaws so i dont have much access to it. i am trying to narrow it down more. but i suppose it needs a cap like everyone said. i just wanna know if the fuses keep blowing, what could cause it to happen?
thanks
SirPeale
« Reply #14 on: September 10, 2006, 08:00:27 am »
*twenty* amps?
Likely that fuse was put there in frustration because it kept blowing.  Then when that one blew they tied the wires together.
Should likely be no more than 3 or 4 amps.
What you need to do is pull the monitor chassis from the tube and start looking for obvious problems: cracked solder joints, burned parts.
Itatemyquarter
« Reply #15 on: September 10, 2006, 04:59:59 pm »
yeah, i read the wrong one. F4--4 amps 250v is it. sorry.
thanks
