Author Topic: changing monitor help  (Read 1229 times)
hunty3000
  • Last login:November 26, 2010, 07:12:37 pm
« on: August 26, 2006, 06:02:22 pm »
hi, i just got this new swp crystal maze arcade machine. but the monitor what was init did not work. i have another monitor to fit it but i dont know how to wire it up. i know one cable is for the power and one for the signal but i dont know where they go.
any help would be great as i really want to get this machine working again.
thank you
Sean
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
Re: changing monitor help
« Reply #1 on: November 05, 2006, 06:26:20 am »
why has know one replied to you thats apoling!
i would like to know somethings about that my self
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« Reply #2 on: November 05, 2006, 10:35:41 am »
Well unless you’re replacing that monitor with the same make and model monitor, you’re most likely not going to have plug & play joy. From the pic the video signals plug into the bottom left corner (green molex). Does not look like the red molex coming from the game PCB will fit. So you have to hack the video cable. Just match the wire colors to the inputs on the chassis. They will be labeled on the chassis G = Green, R = Red, etc. The way you connect it is up to your skill. As far as the power goes, the best I can tell it’s the green molex on the bottom right. It should have a fuse immediately after the input. Some different pictures of the monitor would help.
