Author Topic: RCA Jack for speakers, which is positive which is negative??  (Read 2038 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: August 24, 2006, 12:10:55 pm »
On an RCA style plug for speakers, which is the + and which is the - (positive or negative) ?
see attached pic.
Thank you.
Zakk
  • Last login:Yesterday at 12:51:42 pm
Re: RCA Jack for speakers, which is positive which is negative??
« Reply #1 on: August 24, 2006, 12:22:29 pm »
Outside is negative.  At least on every one I've ever wired up :)
markrvp
  • NFL Expert
« Reply #2 on: August 24, 2006, 12:42:58 pm »
Yep, what Zakk said.  The center pin is positive, the outer ring is negative (or ground).
Izrun
  • Last login:February 06, 2010, 10:32:20 am
    • izrun.com
« Reply #3 on: August 24, 2006, 02:50:54 pm »
I third this!  FYI, this is pretty much the case in most cables (for instance, in coax the outer screwed part is ground, and the same with svideo, usb, etc)
--Izrun
"There are 10 types of people in the world. Those that use binary and those that don't."
