Author Topic: new and improved xml2info xsl now an EXE -- drop in replacement!  (Read 9073 times)
krick
  • Gotta have blue hair.
I just wanted to give everyone a heads up.
I've just uploaded a new version of my xml2info XSL transform.
It's now an exe file called, what else, xml2info.exe and you can just drop it (and the required xsl file) into your mame directory and use it just like the old xml2info.exe.
Enjoy!...  http://mame.3feetunder.com/xml2info/
It's been brought to my attention that you may need to install the Microsoft Visual C++ runtimes to run this exe since it was compiled with MSVC.
« Last Edit: May 21, 2011, 12:38:57 am by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Re: new and improved xml2info xsl now includes batch file
« Reply #1 on: August 24, 2006, 05:49:21 am »
Works brilliantly, thanks very much :)
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #2 on: August 24, 2006, 07:46:49 am »
How do you use the listinfo file for mamewah so as to generate the main list and also filtered list?? would it be rom_folder_vs_dat_file ?? How do you use it yourself Minwah.
The reason why l ask is because l can generate a input filtered list eg -spinner or lightgun list. So would this listinfo file work for that in mamewah??
« Reply #3 on: August 24, 2006, 08:11:53 am »
See this post here: http://forum.arcadecontrols.com/index.php?topic=56050.msg561893#msg561893
I slightly modded my latest beta to get Kricks xml2info.bat to work...however there's an alternative (I think you know this):
From a commandline do a 'mame -listxml|xml2info > mame.dat',
In your Mamewah mame.ini file, set 'list_generation_method rom_folder_vs_dat_file'.
Generate the main list and you should have all filters available as normal :)
rockmes
« Reply #4 on: August 24, 2006, 08:18:30 am »
Mate that was a fast response. l knew it was that Minwah, thanks mate, just needed confirmation.
l'll try it now, and let know the outcome.
rockmes
« Reply #5 on: August 24, 2006, 08:29:54 am »
its not generating filtered list Minwah. l did what you wrote - created a
mame.dat file and changed ini to rom_folder_vs_dat_file.
« Reply #6 on: August 24, 2006, 09:47:15 am »
You need to generate the Main list before you can generate a filtered list...ensure you have the correct list selected*
*a clue is in the menu option...'Generate List' for the main list, or 'Generate Filtered List' for custom lists.
rockmes
« Reply #7 on: August 25, 2006, 07:39:36 am »
one mistake l did was l had the mame.dat file in my mame folder instead of the mamewah folder , thats why nothing was happening. But l have noticed that with using the dat file under generate filtered list ,only the caterogry filters come up nothing else . is that suppose to happen??
« Reply #8 on: August 25, 2006, 08:14:42 am »
It doesn't matter where your dat file is, as you point to it in your (mamewah) mame.ini file
I don't know what you mean....the DAT file can only be used to generate the main list.
rockmes
« Reply #9 on: August 25, 2006, 08:23:10 am »
what l mean is- l can generate the main games list , but when l want to generate a filtered list (eg horizontal games ), its only got the option of generating the list with the category filters only , no other type of filters are available on screen when using the dat file. When l use the normal kirks xml2info.exe ,everything works apart form generating the inputs filtered list. thats what l am really after.
rockmes
« Reply #10 on: August 27, 2006, 02:26:36 am »
Well it looks like after all your hard work Kirk, we wont hopefully be needing your .exe anymore for Minwah has upgrade mamewah to v12 which fixes all the issues we have been discussing about
How happy am l.
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #11 on: August 27, 2006, 10:46:04 pm »
Krick, I still use your EXE with sortinfo.  Thanks and PLEASE keep it updated...
Thanks,
Southpaw
krick
« Reply #12 on: August 30, 2006, 12:39:41 am »
I finally wrote a proper exe replacement for xml2info that uses the xsl transform.
I've removed the other download from my site as it's now redundant.
Enjoy!
Hantarex Polo 15KHz
krick
Re: new and improved xml2info xsl now an EXE -- drop in replacement!
« Reply #13 on: September 05, 2006, 01:25:32 am »
Another minor update.  I tweaked the XSL and my xml2info.exe now works with any MAME version that outputs XML.  I tested it with 84-108.
Hantarex Polo 15KHz
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #14 on: September 06, 2006, 02:45:24 pm »
Thanks krick, again.
Even though I don't use the old listinfo format, I've used your files to build my own lists.  I've learned more about xslt from your files you posted here and elsewhere than from the "howto" web sites I tried to learn from before. :notworthy:
Robin
Knowledge is Power
  • Last login:March 11, 2026, 10:21:07 pm
« Reply #15 on: September 07, 2006, 07:42:45 am »
Agreed.  It is very appreciated.  lronically I'm all xml now even though I was the first to complain, but your add-in means I don't have to worry about releasing the new dk listgen to the public until I am ready.
wilef
  • Last login:August 26, 2015, 08:19:29 pm
    • Mario Bros Arcade Reproduction
« Reply #16 on: December 31, 2006, 01:33:03 am »
for the life of me I can't get xml2info work on my PC.  I'm just trying to get Mamewah to read the real titles of the roms instead of the rom filename.  Whatever I try fails except 'rom_folder'.  Anything involving xml2info fails even after putting your new executable in the mame folder.  It gives me "The system cannot execute the specified program." HELP!
