Author Topic: Ripping at work  (Read 2205 times)
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
Ripping at work
« on: August 23, 2006, 12:50:49 pm »
As I gear up to rip my CD collection (to FLAC in an attempt to "future proof" my effort) I'm looking to take advantage of some idle time on my PC at work and rip a few each day.  My issue is how to best do this WITHOUT installing any software on the computer.
So I'm looking for software that would run from CD (or USB drive).  I *think* the FLAC encoder will run OK from CD.  So I'd be looking for a front-end that would read the CD, hit CDDB/FreeDB, and call the FLAC encoder.
Before it is suggested, WMA Lossless isn't an option since that codec isn't installed (and won't be).
Any thoughts?
More_Beer
  • Last login:December 04, 2013, 04:46:25 pm
Re: Ripping at work
« Reply #1 on: August 23, 2006, 06:18:38 pm »
I wouldn't attempt this. For the fact that, well, even if you get a program to run from CD, you would be accessing 2 drives at once. One for the program, one for the CD you are ripping.
This could lead to errors in the ripping process, and not giving you the best rip possible.
I would be ripping from a program installed onto a hard drive. You only have to rip a CD once, so you may aswell do it properly the first time.
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: Ripping at work
« Reply #2 on: August 24, 2006, 01:28:30 am »
EAC works without installing, should be fine off a USB drive, so long as you have aspi level access on the machine, which you usually do if nero is installed.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: Ripping at work
« Reply #3 on: September 05, 2006, 07:29:00 am »
Not certain if it matters.  Using the ASPI with EAC for 2000/XP machines, it is (was?) dumped into the EAC folder, so it should be accessing it from within that same folder.
« Last Edit: September 05, 2006, 07:48:43 am by DrewKaree »
