Author Topic: WinXP disable password  (Read 1484 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
« on: August 23, 2006, 07:16:27 am »
On bootup of winxp how to you stop it asking for a password
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: WinXP disable password
« Reply #1 on: August 23, 2006, 07:40:24 am »
I believe the answer you seek is here
http://windowsxp.mvps.org/Autologon.htm
NOTE: It is not a good idea to let it auto log into you only administrator account. I have seen a few posts here of users getting into trouble. There is a chance that if windows crashes you may not be able to log into your PC. So create a diffrent account (with or without admin privileges) to auto login (as I do) and all is good.
Futher Tips can be found:
http://wiki.arcadecontrols.com/wiki/Hiding_Windows
« Last Edit: August 23, 2006, 07:41:59 am by loadman »
Havok
  • Trade Count: (+17)
« Reply #2 on: August 23, 2006, 10:55:34 am »
Use TweakUI - that is the best solution I have seen, plus you have a bunch of other configuration options available to you...
bleemus
  • Last login:September 01, 2016, 12:53:24 pm
  • Party Pengo in the house.
« Reply #3 on: August 24, 2006, 05:54:30 pm »
I second that.  TweakUI is very useful for this.
Another great thing you can use it for is to disable autoplay for all your drives easily.  This gets around people being able to run stuff from USB drives without your knowledge.
Reality is overrated.
