Author Topic: Virtua Fighter (Sega Model 1) Question  (Read 1713 times)
MYX
    • MYX Digital Blog
« on: August 20, 2006, 06:45:58 pm »
I just got a VF machine at an auction yesterday. I noticed that the RGB cables were not attached to the monitor and the sound power was not attached. So, when I got home I plugged i the sound and the machine immediatly came up. I had attract sound. I opened up the coin door and got it to coin up. I pressed the player 1 and started pressing buttons and even though I could not see it, I was fighting.  :D Obviously with no RGB cables attached there is still no monitor. My question is this. I have a clear idea of what RG&B is as there is a RGB wires, I have no idea of what is ground or sync as the following two wires are a blue and a white. Whatdoyathink? Ghaw If I can get this to work, this will be sweet. It was sold as totally not working and got it for $10.
M    Y    X
grantspain
Re: Virtua Fighter (Sega Model 1) Question
« Reply #1 on: August 20, 2006, 06:52:01 pm »
blue-common(usually has a white stripe),white -sync
MYX
    • MYX Digital Blog
« Reply #2 on: August 20, 2006, 09:28:58 pm »
Cool thanks.
This plug looks like it connected to something to connect to the monitor. What is the connection type for the monitors?
It looks 8 pins with 1 pin missing. (not sure of exact number) but there are 3, space, then like 4 or 5 pins. I am guessing that the 3 are RGB then the others are +, - sync and ground.. I will look up the monitor tomorrow. Looking for the connector type though so I can pick one up.
M    Y    X
grantspain
« Reply #3 on: August 21, 2006, 06:17:35 am »
sounds like you have a wells gardner monitor,best to find the model number and then look for the rgb pinout(we did not use alot of wg monitors in the u.k,but i remember some had an 8 pin plug consisting of rgb,com,sync and then some wire links),ken will certainly be able to help more-i don't think its a difficult job,i think the connector was just a standard push on type
TravistyOJ
  • Last login:September 19, 2020, 09:34:19 pm
  • DRK LFG!
« Reply #4 on: August 21, 2006, 10:27:25 am »
If it's the monitor that was originally in the VF, it is a Nanao MS8-26SU.  It's a nice dual sync, I have repaired a couple they are pretty unique.  I think RetroJames has some manuals and schematics somewhere, as I remember they are real hard to find.  Also, I have a Virtua Fighter cab manual somewhere that will give you a wiring schematic of the cab.  I will try to find it.
"It is a mistake to think you can solve any major problems just with potatoes."
-Douglas Adams
