Author Topic: Arcade VGA to Wells Gardner  (Read 1537 times)
CPickler
  • Last login:August 20, 2006, 02:37:14 am
    • CPU Studios
« on: August 16, 2006, 08:44:32 pm »
I have a molex connector, the pins to go inside it, and the Arcade VGA breakout cable.  I am trying to connect them to my arcade monitor and have a question before I blow something out.  The monitor connection pins say they need H and V + pulse, whereas the Arcade VGA breakout cable only provides negative H and V pulse.  Is this going to be a problem, and anything else I am forgetting.
SirPeale
  • Green Mountain Man
Re: Arcade VGA to Wells Gardner
« Reply #1 on: August 16, 2006, 09:16:26 pm »
You didn't indicate which WG monitor you have, but you should be able to put your sync pin on the end just fine.
CPickler
    • CPU Studios
« Reply #2 on: August 16, 2006, 09:53:03 pm »
K7200 19"
So just connecting the negatives should be fine?
SirPeale
« Reply #3 on: August 16, 2006, 10:33:19 pm »
Yeah.  Just the end pin.
