Author Topic: WG 25k7197 jamma finger board to vga breakout  (Read 2309 times)
aust_txv
  • Last login:August 14, 2011, 02:55:31 pm
  • Yes Dear, one more game of Mr. Do ...
« on: August 16, 2006, 08:34:49 pm »
Hi All,
To quote another post I am going the "cheap way" and I am there minus a good connection from my PC Matrox G400 to my 25k7197.  I don't want to destroy the jamma connections in this cab.  Can I purchase a jamma finger board and soldier my RGB,G, V/H to the correct spots and plug that into the jamma harness therefore the RGB G V/H on the 7000 chassis ? Other suggestions please ?  Is the J-PAC the way to go ?  I know deep  in my heart he answer is "yes."
As always thank you,
Tom
Personal Log Day 342 ... Still testing my cab. Mr.Do continues to plague me, but the "Pheonix Smash" is automatic. I hear voices "Add a spinner and four-way and your journey will be
SirPeale
  • Green Mountain Man
Re: WG 25k7197 jamma finger board to vga breakout
« Reply #1 on: August 16, 2006, 09:12:37 pm »
J-PAC is the best way to hook up a keyboard encoder to your JAMMA harness.
Not sure how your video card will work out for you, though.
aust_txv
« Reply #2 on: August 17, 2006, 07:06:16 am »
Hello,
I have an I-PAC in another cab and it works fine.  I have gone through the minor work of setting up Advmame and AdvMenu and I have lots of hardware (PC) so I have to get this 7197 singing.
I made a test harness to test my 15k  from a vga card to the 7197...she works and is centered.
Controls won't be a problem I plan to use my I -PAC and not run the cp through the JAMMA harness.  The J-PAC is still in the mix though.
Thanks,
Tom
aust_txv
« Reply #3 on: August 26, 2006, 09:41:40 am »
This can be closed.  Here is the soulution I used to connect my VGA cable to my WG 7000 CGA monitor is a jamma finger board.
If you want to connect a jamma ready cab ( it has the jamma harness and the monitor connection in place ) make a db15 male using RGB G H/V sync, on the other end of the cable you use a jamma finger board and pins n,p 12,13,14. I have h/v twisted together.
Two issues that you must be positive about.
1. Can your arcade monitor take 1v RGB ? or does it need 5v ?
Read the manual.  You may need to make a video amp
2. Is your out put from your PC 15kHz  ?
ArcadeVGA, AdvMame, other ...   "blown up Sir !"
Why not go J-PAC if you have a jamma cab ?
I would love to go J-PAC but the $60.00 needs to go towards better joys and stuff.  Plus I already have an I-PAC.  I still may go J-PAC.   If you are just trying the project out and you aren't sure if you want to put more cash into the cab then for $5 you can make a cable DB15Male to Jamma finger board.
http://www.jammaboards.com/store/jamma-adapters/jb-3-jamma-fingerboard-adapter/prod_130.html
Have fun,
Tom
