Author Topic: Will a 27" monitor fit in a Konami 4P cabinet?  (Read 1007 times)
jhanson
« on: August 14, 2006, 08:00:20 pm »
I was wondering if a 27" Wells-Gardner (like the D9400) can fit into one of those 4-player Konami cabinets (like the Simpsons, X-Men, etc).  I can get a sweet deal on a cabinet without a monitor, but would like to use a D9400 in it.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
Re: Will a 27" monitor fit in a Konami 4P cabinet?
« Reply #1 on: August 15, 2006, 12:45:34 pm »
I tried to look up dimensions on the D9400, but WG didn't have anything for that model.  If you can tell me the width, I can tell you whether or not it will fit.  I would imagine if it does fit, you would have to do a bit of retrofitting anyways.
One thing though, if you want to get this monitor, and it won't fit in the K4p cabinet, I would really suggest you change your mind about the monitor.  This cab is about as wide as you want to go, perhaps even too wide to get through most doors.
jhanson
« Reply #2 on: August 15, 2006, 05:47:35 pm »
Well, assuming it hasn't grown any since the older D9200, it should be 24.4" wide, 21.9" tall, and 16.2" deep (from the mounting brackets back).  Thanks for your help!
davieboynj
« Reply #3 on: August 16, 2006, 12:17:48 am »
it will fit.
